I have an 86 250R and the axle is clunking pretty badly on turns. I did find that the big nut on the right side axle had come loose. Do I have to take that assembly apart to fix clunking? Does it just need readjustment? There is a bolt with a crush ring on the outside of the carrier, does that need grease?
I did have the axle carrier below water a lot the last time I rode, so I may need to repack the bearings with grease. Just wondering what you guys suggest...
Happy Holidays.
Bryan
