Results 1 to 15 of 19
Thread: need help with powerband
    trikeman's Avatar
    trikeman is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2002
    Tug Hill, NY
    237
    when i gun the throttle powerband only kicks in for like a half second then the engine cuts out until i let off the throttle. can some 1 help me?
    Clarks Summit PA
    1,236
    sounds like a jet prob.. what is your jet size? clip placement? mods on the bike?
    Ride it like you stole it! And never look back! They are too far behind to see!
    Jun 2002
    Mississippi
    2,552
    sounds like you need a new powerband. they are easy to replace.
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    trikeman's Avatar
    Dec 2002
    Tug Hill, NY
    237
    it's an 84 250r it's bored 60 dual flap reeds, new piston&rings, new cobra pipe, i'm not sure of the jet size, do you think it would help to put a bigger jet in?
    Ashland City, TN
    2,576
    Quote Originally Posted by 200x Basket
    Are you kidding? Mine cost 360 bucks :shock:
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Jun 2002
    Mississippi
    2,552
    Quote Originally Posted by SSJ3Goku
    you must have bought the red turbo band with the wide elastic and carbon fiber extensions
    83 ATC70
    85 ATC70
    86 500r
    Lots of parts
    My 500R
    Ashland City, TN
    2,576
    How did you know?
    Anyways, trikeman you may want to just put a bigger jet in to see what happens. This is just my opinion but it sounds like your not getting enough fuel to keep it going. Have you checked to see what the air filter looks like?
    Trikes:
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Clarks Summit PA
    1,236
    yepper, if you running a stock jet.. jet up.. whatz the plug read? what plug is it? probaly end up about 3-4 sizes about stock jet for main..
    No, you guys have it all wrong! You don't have to fix the whole powerband just the bearings in the powerband must be binding :-D
    If it was fine before just take out all the jets and clean them good, look for air leaks also.
    Apr 2003
    5
    mabie its the powerbands colour just check to see if its still red
    if its gone green yellow or blue you need to replace it!
    ARC
    84250r is offline Clean enough to eat a potpie off of Teaching quads a lesson
    Michigan
    2,718
    Stock jet,i think is 130
    R.I.P Raven
    2006 Yamaha Banshee Special Edition
    1996 Honda CBR 600 F3
    trikeman's Avatar
    Dec 2002
    Tug Hill, NY
    237
    ok right now it has a stock jet i'll put a bigger one in and see what happens.
    are you guys kidding me buying powerbands. the only way to change a power band is to have your motor ported carb work performance reeds and a performance pipe as to what kind of power band you want. low end to midrange, topend , low end torque. you cant just go and buy a power band. you have to modify your engine to how your want the power band to be.
    finding a good bike is like finding a good woman, it might or might not happen so hang in there.
    Ashland City, TN
    2,576
    I buy powerbands all the time!!! In fact, I have 3 in the mail to my house right now. I like them alot.
    Trikes:
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Jonathan is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    It's obvious what the problem is, it's NOT the power band. He said it works but cuts off. His problem is that his muffler bearing is shot. I mean, how can a power band work properly if the muffler is binding?
    I like motorbikes!
