Results 1 to 15 of 22
Thread: big bore kit for atc 110
    rugabugadouglas's Avatar
    rugabugadouglas is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2006
    iowa
    269
    Question big bore kit for atc 110
    does any one know where i can get a big bore kit for a atc 110 that doesnt require alot of head work? how about any motor parts to make it morepowerfull? any info would be great!!!
    florida
    2,328
    a cam from web cam a custom weld piston porting a bigger carb ect...
    Baltimore, MD
    6,088
    There have been big bore pistons on ebay lately.
    Oct 2006
    iowa
    269
    Smile
    i already have a mukuni carb on it would porting the intake help? also does any one have a pic of a aftermarket frame? i cant think of the 2 names? mine hasone but i want to know which kind i will post pic when i get the chance. keep the replys comming i can use all the help i can get im kind of new to the three wheeler motor ive done a few dirt bike but now im on to bigger and better things than those
    florida
    2,328
    nick nicholson sp??? and i can remember the 2nd
    Baltimore, MD
    6,088
    Nicholson, Bandit, Joker, Hi Performance atv, Johnnys Speed and Chrome. There were lots of them.
    Oct 2006
    iowa
    269
    heres some frame pic
    Attached Thumbnails Attached Thumbnails IMG_1848.JPG   IMG_1847.JPG   IMG_1846.JPG
    Aug 2005
    HI
    1,575
    you can get the 134cc kit for the 110. Stroker kit i believe. I've ridden one...but it was a honda 90 with the kit...FAST!
    Rest in peace Rex Carlson
    Nov 2002
    Ft. Wayne, IN
    81
    You can use a cam from an S90 I found mine on Ebay. K&D cycle in Yuma was a good source for parts I built a stroker with parts from them ended up 13:1 beast!!!I got an S90 race cam off Ebay along with a Joker tube frame and Bandito h/d axle . I set it up with a 185 front end - needed the second brake. Wish I had pictures of it but this was before I had access to a digital camera.
    Methanol, the nectar of the gods!
    Nov 2002
    Ft. Wayne, IN
    81
    Your frame looks like the Joker I had. I don't know if gold was common for a/m frames but mine was also gold.
    Oct 2006
    iowa
    269
    where can i get a stroker kit? and how much work are they to pt it do i have to have the jug bored out and valve work done?
    Oct 2006
    iowa
    269
    also where were the joker frames made and by who?
    Oct 2006
    iowa
    269
    Feb 2003
    Australia
    927
    That frame is a Pauter Machine frame. They are in Chula Vista Ca and are still into the VW engine stuff.
    If you get stuck for a big bore kit, you can use a piston out of a Honda CB125J. There is a little bit of machine work to do to the top of the piston and a rebore. They are 56.5 mm and will give 124cc's.
    There is not enough difference in Honda 90 stock cams to make a difference in performance that you will feel. An aftermarket cam is the only way to go. Watch Ebay. Don't get confused with these 110 pit bike parts, though. They are not the same at all.
    Oct 2005
    Vicksburg, MI
    73
    Whys not start with a atc125 engine or trx125 ('84 and '85 fore sure) same thing but 5 spd with reverse and no H/L. Then big bore them.
    What kind of machine work is needed on top of cb125 piston. Just to lower compression or something else. Im not a bike guy but does it have to be the cb125j. I am assuming there is other cb125's.
