I have a Polaris Scrambler 90 for my son. Its a 2001 model that has not seen more than 7 tanks of fuel thru it. The machine starts right up and idles fine. The problem is when attempting to ride. Sometimes you can hit the gas and go and other times you have to feather the throttle cause the machine bogs down. It will appear to run fine when it takes off OK, but when letting off the throttle to slow down or what not the machine seriously hesitates. I get some back fire puffs occasionaly from the exhaust pipe as well as having to work the throttle to get the engine to take off again. Its kinda hard to explain and if you need a better explanation just ask and I will try and do a better job.
I figured that it was a fuel supply or air inlet problem as th machine seemed to be starving. I removed and replaced the fuel filter that was only slightly dirty. Next I moved on to the airfilter. The air filter was saturated with oil. I removed the filter and started the machine to see if the filter was the problem causing air restriction. It still did the same thing, just slightly milder though. I noticed when the machine was running that a mist of fuel could be seen exiting the carbs intake at idle. I gassed it and to my amazement the mist actually increased instead of decreased. I assumed it would decrease as the air should be sucked into the carb. This would explain why the air filter was so saturated in oil as the carb is spitting fuel into the air cleaner assembly.
So who would like to take a guess at what my problem is? Its obviously in the carb. I blasted it with carb cleaner, but I have yet taken it apart to thouroghly clean. Does this sound like a float issue, or a jet? I am open t suggestions as I have not had this problem ever before.
