I had no luck in a search...
What would be the best at flushing a rear diff on an 86 250? There isnt any fluid in there, its more like a brown buildup about the consistancy of wip cream.
TIA~
TIA~
84 Honda 200ES Big Red
fill it ride it drain it x10
1982 ATC 70
1983 ATC 200E yard rat
1984 ATC 200X
1984 ATC 200S (X2)
1985 ATC 70 (X2)
1985 ATC 200S
1985 ATC 250R
1986 TRX 70
1986 ATC 350X
2004 kfx 700 XC
2006 prarie 700 XC
2009 Brute Force 750
2020 CF Moto 600
^^ exactly what he said. If it's bone dry now, you might put rear end oil in it and roll it fwd and bkwd a few feet to get the gears lubed up and drain it and fill it back before you ride it. I just had to get water out of mine, so I went and got a cheap quart of gearoil, and used about the whole quart in a week, I flushed and filled so many times. I tonly hold about 3 1/2 oz so a quart will last a while.
My Rags
It was so bad the drain plug hole was stopped up. I had to use a screw driver to get things moving so itd drain. With the plug out, I just poured about 1/2 qt of 20-50 through there and when it mixed and drained out the milky crap, I filled with 80-90 gear oil. Im going to drain and refill a few more times. Thanks!
What kinda condition is the trike in? What plugged it up? Rusty watery junk? Good luck getting it back running good. Is this a 86 SX? Are the 85 250ES and 86 250SX rear diffs the same? I have an extra, if you can't get it going.
My Rags
Oh, it wasnt anything Id expect from a neglected trike, just wear and tear. The trike is in really good shape, just need plastics. Anyway, I appreciate the help.
