Results 1 to 9 of 9
Thread: Z's Radiator is leaking.
    Mar 2004
    NE Indiana
    497
    What's the best way of going about finding the leak? I can't see anything wrong...
    1985 Honda 250R
    1986 Yamaha Tri-z
    1984 Honda 200s
    1983 Honda 200x
    1982 Honda 200
    Aug 2006
    new hampshire
    914
    Let Me Know With A Pm If You Need Anything. I Have Radiators And Hoses. I Would Say Start It Up And Look For It To Leak. If Its In The Radiatori Would Just Replace It. Should Be Easyto Findif Its Leaking Externally. Are You Sure Its The Radiator And Nothing Else. If Its Leaking Outside You Should Spot It Right Away.
    1982 ATC 70
    1983 ATC 200E yard rat
    1984 ATC 200X
    1984 ATC 200S (X2)
    1985 ATC 70 (X2)
    1985 ATC 200S
    1985 ATC 250R
    1986 TRX 70
    1986 ATC 350X
    2004 kfx 700 XC
    2006 prarie 700 XC
    2009 Brute Force 750
    2020 CF Moto 600
    Solid Snake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    Lancaster, PA
    316
    I've seen stuff at Autozone made just for fixing leaking radiators. Not sure how well it works but it may be worth a try. I saw it around the gasket sealers, glues, and stuff like that.
    Trikes
    1984 Honda 200x, 1984 Honda 200m
    Bikes
    1995 Honda CR125R, 1985 Honda XL100 (gone), 1982 Kawisaki KZ550 LTD,
    2001 Yamaha TT-R 125L, 1983 Honda XL185S (current project), 2001 Suzuki SV650S
    illinois
    743
    take them to a radiator shop
    or -thers some on ebay
    Mar 2004
    NE Indiana
    497
    Ok, so, it only leaks when it's running. If there was a hole in the radiator, wouldn't it leak all the time? Should I go ahead and look for the tube?
    1985 Honda 250R
    1986 Yamaha Tri-z
    1984 Honda 200s
    1983 Honda 200x
    1982 Honda 200
    Mar 2004
    NE Indiana
    497
    Ok, so I found the leak. It was the fluid containter, it has a crack in it. Now, will an '85 work with an '86?
    1985 Honda 250R
    1986 Yamaha Tri-z
    1984 Honda 200s
    1983 Honda 200x
    1982 Honda 200
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    put a raw egg in it and run it, lol seen it on mythbusters and it worked!
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
    Billy Golightly's Avatar
    Live Oak, FL
    15,067
    No. The 85-86 overflow containers are different. THe 85 mounts under the seat and the 86 on the side of the frame above the sprocket.
    Mar 2004
    NE Indiana
    497
    Damn. Ok, thanks.
    1985 Honda 250R
    1986 Yamaha Tri-z
    1984 Honda 200s
    1983 Honda 200x
    1982 Honda 200
