Results 1 to 15 of 17
Thread: Snowmobile motor in what quad?!?!
    Coopersville Michigan
    41
    I just picked up a 440 air cooler motor out of an older sled. I would like to slap it into a quad. What i need your guys opinion on is what chassis would be the eaisest and most affordable. I have no concern how of good it looks or how good it handles around corners. I just want a straight line rocket. Also i know its going to require custom motor mounts and a lot of welding and perfect fit but i can handle all that
    My first idea was a blaster
    What do you guys think??
    Jake
    Jul 2006
    miami florida
    88
    i would search around for the cheapest rolling chassi i could find but that just me
    i see alot of people do motor swaps in DS650 frames they are pretty big
    41
    yeah a ds 650 would have a lot of room but i think those rolling chasis would probably cost a lot of more than i want for this project
    Anybody else have idears?
    Jake
    Dec 2002
    Kansas
    2,387
    Any older polaris quad, might as well have the ultimate sleeper.
    I had the RIGHT to remain silent, I didn't have the ability!
    Jul 2006
    yea Ive seen alot of polaris's with snow motors in them as they still have the auto hooked up, I think te biggest was some kind of three cyl 900 in a polaris trail blazer it was stupid fast
    41
    Im not really familair with the entire polaris scene....what older ones are you guys talking about? Like the trailblazers and what else?
    Now that you guys say that i do know a guy with a 500 polaris motor in a newer 4X4...dont know if he ver finishied the project or not
    Jul 2006
    yea from what I was told alot of polaris snowmobile motors will actually bolt right in a polaris quad, the only big mod is getting the pipes to workl and the motors will hook right up to the cvt trans
    Jul 2006
    oh the older early 90's polaris's thats what years 90-98 would be good
    41
    the bad thing is my motor isnt a polaris its out of a scorpion i believe....that might make the entire bolt up thing a little bit more difficult
    Jul 2006
    well the good thing about the polaris is the cvt makes it easy to have a trans, also the porlais's frame is flat under the motor for easier mounting, plus Ive seen blown polaris's go for cheap
    conig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    tallahassee FL
    392
    not neccasarily true I think they mean this chassis. but it will not be bolt in the polaris quads use p85 clutches and snow mobiles use p90(I may have that back words. polaris secondarys for quads use a thiner belt, and they mount on splines, snowmobile secondary clutches use a key way to keep them in place and a larger belt.
    ive known to people to try this, first one had to use a jack shaft as he seriously stweaked his frame from the torque first time out, the tranny literly pulled at the mounts and bent the frame up by the swinger.
    the second I beleive did extensive frame reinforcement and a jack shaft. heres a pic of mine with no motor maybe it will give you a space idea, the second pic is of the machine my friend in Louisianna built.
    1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
    1985 honda es 250 big red.
    85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
    A trike to show up the modern utilitys
    2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
    85ytz250n is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Waynesboro, MS
    338
    I am doing the same thing, except differant. I am going to take a quads suspension and make a buggy with a sled motor, using the rear from a polaris and the front from a blaster. I am going to use a fiberglass seat from an old circle track racer. The main reason that I am going this route is that all my parts are going to be free, even the two quads and most of the metal. The only thing I am going to have to spend money on is the motor because I am going to get the whole sled and use everything that i can, gauges and the like. Good luck on the quad though, should be a bad ass ride that would give most modd'd shees a run for their money.
    Barry
    There are no stupid questions, but there are alot of stupid people out there that ask questions.
    None of us are capable of screwing things up as bad as a group of us.
    "NON SIBI, SED OMNIBUS"
    41
    i know im probably going to get flamed and called a dumb ass for this but is there and way you could possibly convert it to chain driven... i knew i kid in high shcool that did this but i can seem to find him around here anywhere for the life of me!
    Thanks
    Jake
    Aug 2005
    Oregon
    490
    Best thing to swap a snow mobile engine into would have to be a Honda FL250, not quite a quad but fun none the less
