I Have a very nice running 88 TRX 250R jug that I purchased, which needed a re-sleeve. They sleeved it over the original sleeve at, I believe 68 mm for a 265.
I had plans on having it sleeved for a 295 at 72 mm.
I removed the over-sleeve, which just fell apart once I got an edge. This left the overbored original sleeve. I used my Dremel to score it almost to the cylinder casting.
I then got a grip on the bottom, and carefully twisted so the sleeve split. This caused it to loosen up in the bore, and I was able to pull it out.
Upon removing it, I noticed that the casting barrels out in the center about .100" to .130". I also noted that this larger diameter of the cylinder casting is a touch over 72 mm.![]()
Is this cylinder still going to be useable with a 72 mm sleeve inserted, or did I just turn it into scrap? I am assuming they will have to bore it to at least 76 mm for the sleeve. Is that a wrong assumption?
If it is still useable, who does quality 295's for reasonable? I was looking at possibly using Kustom Kraft. Also, would it be wise to O-ring it, or are the big-bore head gaskets pretty good now?
