Results 1 to 8 of 8
Thread: Rear Sprocket 85 vs. 86 350X
    Oct 2005
    Iowa
    47
    Is there a difference? Can I put a rear sprocket off an 86 on a 85 350X?
    Thanks,
    dvalley
    Aug 2005
    Portland Or
    412
    No difference...85 or 86 youll be good to go.
    "Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut."-Ernest Hemmingway
    wales..uk
    1,318
    Quote Originally Posted by 350xBomb
    the 85/86 are different....86 sprocket has countersunking where the mounting bolts go.....to convert a 85 to a 86 you need to find the countersunk bolts and nuts....then it will work otherwise your chew the carrier up.......
    Need Honda ATC TRX NOS restoration parts??? or come check out our ATC brochure site
    www.offroadvintage.com
    Oct 2005
    Iowa
    47
    Does anybody know where I can get these bolts?
    Tionesta, PA
    5,739
    any honda dealership will have them. I have the 86 carrier and sprocket set up on my 85. It is good to do this because 86 carriers are the same as 250X 300EX and 400EX carriers good aftermarket availability.- 85's are not the same.
    Aug 2005
    Portland Or
    412
    Boy is my face red...I had the 86 carrier too and didnt even think about that. Sorry for the misinfo.
    Bartlett TN
    3,083
    I had the same problem with my 85 250r. I had to buy the bolts at service honda and they cost me around 31$ shipped.
    86-87 Tecate ROCK!
    Hampton, Virginia, C.S.A.
    2,664
    i have a 86 rad bearing carrier on my 85 350x....the countersunk nuts and bolt are expensive...i went to the local hardware store and found some bolts with smaller heads...the heads are about half the height of the stock 85s...if you do this take you old bolts with you and make sure you are getting smaller heads...and get stainless steal grade 8
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
