will the brake calipers off a 200x front and rear work on a 250r?
the 82-4 250R's brakes are the same as the 83-5 200X's calipers for the front. the mounting brackets are the biggest difference
1985 KXT 250
84 KX cylinder
sprock racing head
+2" Miltech swingarm
frame mounted Rad
1983 250R
DG head
290cc Big Bore
CT pipe
85R front end
+1" Miltech swingarm
2+2 axle NOS NASA
18x10x9 Hoosiers
well im looking at picking up a 84 250r, needs front and rear brake calipersOriginally Posted by ATCWRENCH
i have a 200x parts bike with both.
you are saying they are pretty much the same but won't bolt on?
the calipers themselves are the same. its the bracket that is used to bolt it to the fork is different. so to use a 200X caliper on an 84R, you need to get a hold of an 84R caliper mounting bracket and put it together with the X caliper. no mods, direct bolt on. you may even try to bolt the X bracket to the R forks and see if it will work. the 83-4R brackets might be the same as the 83-5 X brackets
1985 KXT 250
84 KX cylinder
sprock racing head
frame mounted Rad
1983 250R
DG head
290cc Big Bore
CT pipe
85R front end
2+2 axle NOS NASA
18x10x9 Hoosiers
cool, ill ask if the r comes with the brackets on it or not
I used a 86 200x caliper on a 84 250r front end, without doing anything, unbolting it, and boltiing it back on 84r forks. I didn't change the brackets, maybe 83-85 was something different??
