Results 1 to 6 of 6
Thread: question about 250r brakes
    St Helens, OR
    611
    will the brake calipers off a 200x front and rear work on a 250r?
    Jan 2005
    Great Bend
    704
    the 82-4 250R's brakes are the same as the 83-5 200X's calipers for the front. the mounting brackets are the biggest difference
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    St Helens, OR
    611
    Quote Originally Posted by ATCWRENCH
    well im looking at picking up a 84 250r, needs front and rear brake calipers
    i have a 200x parts bike with both.
    you are saying they are pretty much the same but won't bolt on?
    Jan 2005
    Great Bend
    704
    the calipers themselves are the same. its the bracket that is used to bolt it to the fork is different. so to use a 200X caliper on an 84R, you need to get a hold of an 84R caliper mounting bracket and put it together with the X caliper. no mods, direct bolt on. you may even try to bolt the X bracket to the R forks and see if it will work. the 83-4R brackets might be the same as the 83-5 X brackets
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    St Helens, OR
    611
    cool, ill ask if the r comes with the brackets on it or not
    Jun 2003
    englishtown NJ
    2,676
    I used a 86 200x caliper on a 84 250r front end, without doing anything, unbolting it, and boltiing it back on 84r forks. I didn't change the brackets, maybe 83-85 was something different??
