Results 1 to 3 of 3
Thread: ATC 185 Questions?
    Sep 2006
    Stanwood, WA
    ATC 185 Questions?
    I'm getting a good deal on a Honda ATC 185. The trike is in great shape, runs fine and all, but has the rigid front forks. Is it worth the effort to swap over the forks to the newer style with suspension?
    I've also been researching some fo the big bore kits, which use the 200cc cylinder jug. Is there a productive gain in power with these? I'm a big guy, and want some more low end grunt.
    Des Moines, IA
    1,292
    Not only worth it, but some would say a requirement! The non-suspended ATC's will beat you to death, but even the limited 185s-200s front shocks make a huge difference.
    Dunno about the big bore kits, someone else will have to answer that one.
    God knows they're not looking to make any effort to do anything, never mind move their foot to shift. If there was something that dispensed Cheetos every time they shifted that might be a different story. Welcome to America, where the biggest is best and even fat people who are too lazy to shift can climb a mountain.
    Sep 2006
    Stanwood, WA
    Is the front hub/brake assembly the same on the non-suspended forks as on the telescoping suspension forks?
