Results 1 to 8 of 8
Thread: 200x valve adj tools
    Apr 2005
    Blue Ridge Mtns NC
    59
    Question 200x valve adj tools
    I see in the Honda manual that there are a couple of "special" tools needed to adjust the valves on my 85 200X. Does anyone know if these tools are really needed, or can you get good results using a standard feeler gauge set with a screwdriver and wrench?
    The Honda part numbers are 07708-0030200 and 07708-0030300. Service Honda don't even recognize these numbers?????????
    please advise. Thx!
    Aug 2004
    Nampa, Idaho
    1,245
    Cool,
    Let me know how difficult it is to do. I'd like to adjust the valves on my 85 200x also.
    Nov 2001
    B.C.
    933
    Use a 10mm wrench and a #2 Robertson (socket head) screw head. Works great. Fits just like it was made for the application
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Jan 2005
    Great Bend
    704
    I adjusted the valves on my 85X with standard garage tools and an everyday feeler gauge. the only problem I had is when it was time to re-tighten the jam nut. its kinda hard to keep the valve tappet in adjustment when you tighten the jam nut. one way to get around that is to get a boxed end wrench with two really tight 90degree bends in it. one down and one out, that way you can keep a screwdriver on the tappet so it stays in adjustment and then you can put the end wrench on the jam nut and tighten it.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Pa.'s Highest City
    8,058
    You guys are confusing me more than I already am. I'm almost certian the x is the same as on my SX...
    I big flathead screw driver to take the timing caps off. (if you run the engine they expand and loosin)
    a 17 mm socket to turn the motor over to find the timing mark in the window.
    10 mm wrench or socket to take the valves caps off
    A feeler guage (I've found the angles ones work better) Also you need the correct size) .008 on both side on mine (SX)
    a set of long nose plies and a 10mm wrench to hold the top of the valve and tighten the nut on top of the valves.
    Now since I'm posting I want to take the oppertunity to ask a question as well.
    Once you turn the motor over and get the piston TDC on the compression stroke the exhaust side will loosen up first... (you can wiggle it with your finger) Once you have got that one squared away do you just go ahead and do the otherside... OR do you have to do another cycle to TDC? on the compression stroke? Can some one walk me through this step?
    I adjusted mine a week or two ago and it's still ticking a bit too much for my liking...
    sorry for buttin in...
    Jan 2005
    RI
    2,530
    they both should be loose at TDC...
    if they arent, youre not at tdc on teh compression stroke
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Pa.'s Highest City
    8,058
    Quote Originally Posted by DeePa
    Thanks.. I believe I did it wrong then... (meaning not on the CS)
    the compresion stroke is when it gets tougher to turn the motor I'm guessing.
    sorry again...
    Jan 2005
    Great Bend
    704
    remove you spark plug and the motor will be a lot easier to turn over. also remove your valve adjustment caps, this will also aid you in finding true top dead center. it may not hurt to have friend help you do this as well by sticking a screw driver through the spark plug hole to slow the piston down so it doesnt rotate past TDC. it happend to me about 4 times before i got a friend to help me out.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    2+2 axle NOS NASA
    18x10x9 Hoosiers
