Originally Posted by
burnoutboy
I personally have done this. Electric starter will NOT fit without modification. You will have to grind a notch in the downtube which will affect the strength of the frame.
You have to then sort out a battery box and a wiring loom.
Yea, if will work, but you will either need to grind a notch in the frame where the starter goes or just hit it with . If your trike has the trunk on it, you can put the battery in there, just secure it down somehow, mabey zipties? Look at pics of the 82-83 Big Reds to get a idea of where to mod your frame, or just look at a friends.
TF 07,08,09,10,11,12,13,14!
