Results 1 to 12 of 12
Thread: banshee swingarm to tri z ??
    Oct 2005
    uk
    87
    might be a stupid question but will a banshee swingarm fit a tri z.
    or as any 1 done it with mods ?
    thanks again ian
    Rittman, Ohio
    6,276
    Not even close. Blaster is closer, but its a downgrade.
    Ontario, CANADA
    4,538
    Downgrade cause its shorter Tim?
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Oct 2005
    uk
    87
    thanks for the replies.......
    only asked cos thats all i was finding on ebay ??
    Mar 2003
    Kansas
    1,507
    A 660 raptor is fairly close, but would take a little machine work. I just about ran one of these because they are aluminum. The big thing is the front, where its notched for the motor. Its been a good year or so when I had one and was figuring it all out, so I forgot what exactly needed to be done.
    Rittman, Ohio
    6,276
    Quote Originally Posted by Kintore
    No, its a downgrade because the Blaster does not use the linkage type suspension setup of the TriZ which is far supeior to the straight length shock system.
    The TriZ swingarm pivot bolt runs through the rear of the engine which sits inside the swingarm pivot. I dont know if you could make a Blaster one work, but its a similar style, but no reason when TriZ swingarms sell really cheap.
    There is a general assumption that with swingarms longer=better and nothing could be further from the truth. A swingarm length is chosen for a specific purpose or goal. If you choose a longer or shorter swingarm for one purpose, chances are it will hurt you for another purpose. Ifa longer swingarm was magic bullet fix all, they would have simply made them with longer swingarms.
    na
    5,702
    the only way i tried a shee swinger in a z frame, is when i mocked a shee motor in the z frame.if you were going with a engine that does not need the swinger bolt in the rear of it,the banshee swinger pretty much fits right in the z frame. i did notice that a couple of 1/32 shims will be needed but no other mods were really needed. i did not get as far as the shock or dogbone linkage though. so i dont know what would be needed there.
    Proudly NOT a member of
    "Team on the Teat"
    Aug 2006
    new hampshire
    914
    i have two tri z swing arms if needed $50 each plus shipping.
    1982 ATC 70
    1983 ATC 200E yard rat
    1984 ATC 200X
    1984 ATC 200S (X2)
    1985 ATC 70 (X2)
    1985 ATC 200S
    1985 ATC 250R
    1986 TRX 70
    1986 ATC 350X
    2004 kfx 700 XC
    2006 prarie 700 XC
    2009 Brute Force 750
    2020 CF Moto 600
    Tuscon,AZ
    77
    Quote Originally Posted by moshman355
    banshee motor in a z?you got any pics?
    tryin to get back on the map
    ex toys
    82 atc200 SOLD
    82 atc185s- In pieces in the desert somewhere
    83 atc185s- thrashed and left in texas somewhere
    83 atc110 in pieces in the desert somewhere
    83 trimoto 175- Clutch exploded and almost took off my foot
    1987 CBR600F hurricane- Parted and sold
    1982 Yamaha Seca 750- Sold
    1992 CBR600F2 thrashed and left in the junkyard to rot
    1994 CBR600F2 punched a mailbox, mailbox won...
    1997 Hyunai EGG....slower than my 110....donations please?
    na
    5,702
    i said i mocked it in there. in other words i just put parts in loosely to see what had to be done to make the real TRI-SHEE.for now i have abandoned the idea. i will be building a 310 big bore tri-z instead.
    "Team on the Teat"
    Tuscon,AZ
    77
    dude you should do it anyway.....thats the best idea ive heard yet....like a 250r motor in a trimoto.....how much work would have to be done to the triz to fit the shee motor in it?you mind if i message you?
    ex toys
    82 atc200 SOLD
    Quote Originally Posted by fasttrimoto175
    guess we'll just have to wait till nathen's done wont we,,,
