Alright the machine is a 1983 Honda 200E, lower hours and probably the first time it has been apart. I replaced the stator and figured I would remove the cutch cover so I could clean the oil rotor. Since I had the cover off I also put in a clutch kit (friction plates and springs) that I had hoping it would make the machine shift easier (it shifts ok but is hard to get into neutral and just takes more force to shift then I would like). So after letting the new clutch plates sit with oil on them overnight I put them in today. Everything went together fine but when I started it; it would sit but not go anywhere. So I took the clutches off again to inspect everything, it looked ok. I tried shifting the bike without the clutches in and it seemed to work fine, after installing the clutches I tried again and still it felt fine. So I put the cover back on, fill it with oil, adjusted the clutch, and start it up. Now it jumps a little when I shift it into gear but still won't move. What do I check now? Did I forget to do something?
