Do you need to Grease the U Joint on a 250SX? I was thinking about looking under the rubber boot. After I look inside the boot, do I oil or Grease the U-Joint?
1986 Honda ATC 350X Stock
1985 Honda ATC 250R Stock
1985 Honda ATC 250SX Project Need Parts
1983 Honda ATC 110 Rare Blue Model
1982 Honda ATC 110 Front Brakes
1983 Honda ATC 70 with Lights
1979 Honda ATC 70
http://autos.groups.yahoo.com/group/HondaATC/join
Anybody know?
1979 Honda ATC 70
Well the owner's manual say's nothing about the Ujoint or drive shaft. But it does say to put 3.2 ounces or 100cc's of gear oil in the differential.
Anyone know for sure. Since I have mine all apart at the moment now would be a good time to know for sure.
http://www.3wheelerworldforums.com/a...8&d=1155345744
The service manual indicates no grease to the universal joint, but to apply grease to the shaft splines.
Cannot be greased, I've never worn one out that didn't get water in there. Splines get rusty if you don't address the SX's flaws...
OK how do you keep rust off it?
1979 Honda ATC 70
Tear it all apart, file and stone every surface perfectly flat. Put silicone on all mating surfaces and under the boot. Put all new seals in and put the thickest grease possible on all spline surfaces.
