wanting to knowif a reed cage from the cr250 models bolt onto the atc cylinders. any advantage? disadvantage?
1985 250ES ATC
1985 200X ATC
1984 250R ATC
1983 LT-50
1991 LT-80
1996 YFB-250
>->->->Hgoody77@yahoo.com
We use them on the TRX'S .. THERE bigger for The 39mm Carb's , but...............
they are shorter and the angle is more towards the frame ....
some Motor Builders like the carb. closer ... some like it farther away for mid power
"07" DR650 Suzuki Dual Sport
well i was thinking reed cage only, not like rad valve were it has trhe carb mount built in. just the cage and i guess the thickness of were the bolts go through, but yeah, i didn't know if the cage would fit at all?
1985 250ES ATC
1985 200X ATC
1984 250R ATC
1983 LT-50
1991 LT-80
1996 YFB-250
