Results 1 to 10 of 10
Thread: Gorr ported 250r first impressions
    Ndog is offline First Time Rider Arm chair racerNew to the board
    Naptown
    115
    Whats up guys? Just got my beast back together with pretty much all new everything. Here is the list..
    Mo Better Eric Gorr overbore, head shave, port and polish
    Wiesco Pro lite piston & Rings
    38mm Keihin Air Stryker
    Boyesen RAD assembly and reeds
    Brand new OEM clutch and plates with stiffer springs
    Clutch update kit from Service Honda
    Rebuilt front forks (all internals still available)
    New rear shock and reservoir (finally can adjust)
    Durablue +4 axlle with spacers ( this thing is wide!!!!)
    Lonestar double bearing axle carrier
    Durablue anti fade disc hub/ axle nut assembly
    I polished both crankcase covers and the forks. Got some plastic-glo compound and a mushroom buff from Caswell for the plastic. Gastank looks sweet but havent done the rest.
    This thing rips nuts!!!!! Gases up wheelies in all gears. Feels damn near like my 00 CR250. One problem. I STILL HAVE A STOCK PIPE!
    I have an old performance silencer on it that I repacked but that damn OEM pipe is all I have.
    If this thing is ripping like this now, how much would I gain by putting on a Paul Turner Hi Rev or ESR ATC5? Am I missing out?
    Help Please!!!!
    Jun 2003
    englishtown NJ
    2,676
    it will be faster with a pt turner pipe, get the pipe that meets your needs, type 6- woods riding, hi-rev- mx and dunes, open areas.
    Jun 2004
    Oregon
    1,772
    Pt hr should work perfect for ya!
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Boyesen Rad Valve
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
    Rancho Cucamonga, Ca
    228
    I just got my atc-5 esr pipe, silencer and flange coming from a stock pipe. Huge difference. Espcially for the mid range hit. I ran stock a long time, wish I changed sooner.
    own:
    1986 250R- ported polished, carb mods, Esr atc-5 pipe and silencer
    1986 250R- mild porting, carb mods (Clean!)
    1985 350X- all stock (super clean!!)
    1985 350x- desert project in the works
    1986 250sx- Mostly stock
    1985 200x- (pretty clean mostly stock)
    1985 Yamaha tri zinger 60
    Nov 2005
    arizona
    61
    ya i am putting a atc-5 esr pipe on my bike soon. gl with *Edited**Edited* decision and nice job in bike
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    so how much that EG porting cost?
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    Jun 2004
    potsdam ny
    1,227
    any nice aftermarket pipe would be much better....the stock pipes are all jokes...get an esr or a PT hi rev....sounds like a nice ride, almost the same mods i have done and its def the way to go....i wanna see pics though!!!
    you may want to get a hinson adjustable counterbalance holder , your motor will like 2 or 3 degrees advance with porting and a shaved head.... with a couple degrees of advance and i nice pipe, your setup should have easy 5 or close to 5 more hp, no joke. your really holding the power back with a stock pipe.
    Anaheim
    1,270
    ill second HRC on that, a pipe alone with a good port and jetting will add 5+ horses... now your R is flowing HUGE amounts of Air going in and try to push it out through a straw, sorta like filling up a funnel with a peice of quater inch hose and asking for nothing to overflow..... I would defently go either PT HR or ATC5, the benifits of the ATC5 is its basically a BIG bore atc pipe, meaning you can never OVERflow that pipe, guys run stock 250's to 380 motors with that pipe and never feel like the exhaust is holding back.... i have never seen a bigger then 310 motor with a HR... either one is a great pipe, they are 2 of the 3 remaining builders for the ATC250R pipes, so that leads to their creditablity... when i step up (pretty soon... ill go ESR)... best bet is to ask Eric Gorr what to run... your porter will be the best guy to ask..not abunch of horsepower junky's on the net! LOL
    Adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    Naptown
    115
    Thanks guys!
    ((Don't bypass the word filter))
    Right now my main is 180 and pilot is 40. Rich for sure on idle and main could drop too. But with stock pipe and break in its ok for now.
    Im thinking 170 main and 38 pilot for the 38 striker.
    Im in Indiana at near sea level and 90 degree humid days.
    Sound about right? Seriously, ESR or PT too? I have alot of flat track but also trails. Im thinking ESR ATC5.
    Thanks again dudes!!!!!!!!!!!!!!!!!!!!!!
    Anaheim
    1,270
    i ran on a trinity stage4 cylinder, 48 pilot 172 main clip position dead center, bike ran like a raped ape
    Adam
