Results 1 to 8 of 8
Thread: Big Red vented gas cap not venting
    Apr 2005
    Elrod, IN (near Milan)
    114
    Hey guys. I just bought a 1985 Big Red. It ran perfect for about an hour or so and then died. I quickly found it was not getting gas to the carb. I changed the filter, hopped back on it only to find it quitting again in a couple of minutes. Petcock is working fine. Took the gas cap off and heard a rush air enter the tank. Checked the vent and it was in the "on" position. Is there a simple fix for these or is the cap junk? For now, it's sitting loose on the tank, allowing enough air inside to keep it running. I need a fix before TF'06. Running a loose cap at Haspin won't work!!! I don't see any way to take it apart. Any replies will be appreciated. Thanks wheelerheads. ATC4everBob
    Eastern Long Island
    1,688
    I just had the same problem on my 125M a week or 2 ago. The gas cap is still available from Honda and was like $32. I know it is the same cap as the BR since I borrowed that one to ride the 125M. The part # is 17620-HC3-771.
    Lots O Trikes!!!!!
    CorbinKale's Avatar
    CorbinKale is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2005
    NE Texas
    179
    Quote Originally Posted by jeswinehart
    I am sure my friend had a extra in the tool box. She will never need it. I will stop by and pick it up and try it out on my bigred to make sure it is okay and all.
    I can bring to Haspin with me on thursday if you want.
    This will be a free part by the way ,,, I will post my findings tomorrow night ( with pics - everybody wants pics )
    john
    You are going to be so busy passing out parts, you won't have time to ride!
    CPSC: Pissing in the gene pool, since 1973.
    springville, PA
    6,185
    well not the recommended way but hey it worked great
    http://3wheelerworldforums.com/showt...ht=gas+cap+fix
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Apr 2005
    114
    john
    Hi TF Chef. Good grub last year, dude, THANKS from everyone !!! Yeah, if you don't mind packing the gas cap with you, I will be at TF on Friday morning. I may run into one *Edited**Edited* TF, but I doubt it. Thanks for your help. ATC4everBob
    Maine
    466
    If you flip your cap upside down, look where the neck part and top base meet{90 degree angle} take a small dril bit 1/16 and drill through the first layer , I have done this to mine before and it worked, try it , its a cheap and quick fix
    Mar 2005
    Underwood North Dakota Tiger country
    1,055
    atc forever if swinehart don't have one i will throw a extra in I have a few spares
    Trikes currently owned
    E.T. trike 150H.P. and climbing Pure DRAG beast
    85 250r project
    drilling that 1/16 hole does the job! Ive done 4 or 5 of them, you never have to worrie about it again!!
