Thread: what's the difference between DR8ES-L and DR8HS
    springville, PA
    6,185
    I have like 9 plugs here that go to a 110 brand new and they are all DR8HS and my quadsport plug fouled and thats a DR8ES-L. Now after looking at the 110 manual it says the 125m came with a DR8ES-L so I'm thinking the DR8HS is just a cooler plug?
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    check the thred length on them I think HS is 1/2 long and the ESL is 3/4 long
    broook's Avatar
    broook is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2003
    Newfoundland
    207
    Quote Originally Posted by 250sxwheeliepop
    The "8" denotes the heat range in both plugs. The "-L" is one half a heat range higher and the "H " means part threaded. With a KLG plug the lower the number the hotter the plug. Dr8es-L is the Canadian plug with the "R" standing for resistor. You can switch to the American plug D8EA if you like.
    Newfoundland
    Sep 2005
    Lipetsk, Russia
    2,824
    Yeah, HS is a lot shorter (2 to 4 threads, i think) than the ES
    springville, PA
    6,185
    well it performed beautiful today so there wasnt a big difference between the plugs
    Nate
    R.I.P HRR
