I dont no how to tighten my chain on my 1983 250r.....does anyone know how to??
if you look at your swing arm where the axle goes through you will notice on the inside of either the brake rotor or sprocket you will see teeth/grooves that wrap all the way around the bearing carrier. now the two bolts that hold the carrier tight on the back of the swinger need to be loosened up so the carrier can rotate. get a spanner wrench from your local atv dealer and use it to adjust your chain. once your chain is adjusted, retighten the two bolts on the back of the swing arm and you are good to go.
1985 KXT 250![]()
84 KX cylinder
sprock racing head
+2" Miltech swingarm
frame mounted Rad
1983 250R![]()
DG head
290cc Big Bore
CT pipe
85R front end
+1" Miltech swingarm
2+2 axle NOS NASA
18x10x9 Hoosiers
Hey, I just did the chain on my R a few weeks ago.
Instead of using a regular chain tensioner like on most dirt bikes, Honda used an eccentric bearing carrier inside the swing arm. They did that so that when it was rotated, the chain could be tightened and loosened.
If you look at your swing arm, you can see stubby looking things sticking out on the right hand side. You need to get a spanner wrench to go over them and then pull on it to rotate the carrier. I used a yamaha wrench and it worked fine.
First you have to loosen the 2 hex bolts the hold the carrier in place. They are on the back end of the swing arm. Then you have to loosen the actual carrier itself.
if your trike is anything like mine, then this is something that hasnt been touched or loosened in 20+ years, so dont just go crankin on it you may break something. Soak the outer side in wd40 to loosen it, then take it slow.
After I did those things mine went well, and its nice to not have the chain fall off now everytime after I do some powerslideseveryone else let me know if I left anything out. Good luck dude
I would think that its like a 350X. If you look at the rear of the swingarm front he back of the bike, where the axle goes thru. On the left side there should be a colar with some teeth sticking up that goes all the way around. If you turn that piece one way it should tighten. You may have to use a screw driver to tap it around. This will take the slack out, unless the chain is shot.
Clay Whitman
Newnan, GA
AMSOIL DEALER
My Toys
2008 Yamaha Rhino 700 SE
lol, beat my about 2 minutes ATCWRENCH.![]()
ok thanks people.....i'll try it soon
I put mine on blocks, fire it up, put it in gear and tighten the chain so you can just fit your finger around the rear sprocket. otherwise the other methods work as well.
85 atc 250r;
PSI porting & head mods
fmf pipe & silencer
boysen rad valve & reeds
38mm air stryker
Its some hard tightening the chain on a 250r compared to a 250sx or a big red![]()
WWW.FASTRACKZ.COM!! Totally dedicated to Atv's/MX/Sleds. Go take a look at the photoalbum and drop into the forum and say hello!
Originally Posted by nate b
Argh. Did you ever check out the thread on losing fingers?
http://www.3wheelerworldforums.com/s...ghlight=finger
1980 110
1982 250R
1985 200s
1985 250R
1985 350X
Parting out...
1983 250R
1984 185s
PM me for parts
