Results 1 to 3 of 3
Thread: 1985 Tecate Project
    Feb 2003
    100
    1985 Tecate Project
    I picked up an 85 Tecate that is 95% there that needs some TLC. It has a few decent parts including Keihin carb, DG exhaust and Works Ultracross shock. My questions are:
    1.Are aftermarket fenders still available from Maier?
    2.I believe these have Nikasil cylinders which I are not boreable. What do I do if I found out the cylinder is scored? I think it has a broken ring.
    I have already found some odds and ends on Ebay so hopefully I will have it going sooner rather than later. Thanks.
    Newfoundland
    5,280
    Try and find an 83/84 KX 250 cylinder and buy a KX250 piston kit to install. That mod alone will net you some pretty big performance gains. Prefereably have the Nikisel repaired in the stock or KX cylinder but a sleeve will be just as good. I have two sleeved cylinders for my T3 and they run fine.
    The carb is a good score as the original is trash since its likely to be worn out. What size?
    Maier makes green and red front and rear plastics for your T3. I find the 86/87 plastic fits with some mods and looks better.
    Is yours the 85 red or green version? Pics?
    James
    Feb 2003
    100
    Thanks, it's the green one. For some reason, the pics won't load. I'll get some more pics and post later.
