Results 1 to 10 of 10
Thread: Please Help! I'm losing patience!
    Oct 2005
    North Branch, MI
    196
    ok, i get my trike out to ride it. YTM 200k. it starts right up, and idles perfect. i ride it around and it runs good. i get on my trail that is pretty straight so i can open it up a little bit. i the throttle, and the motor starts missing. i mean missing bad. but if i let off the throttle and just drive it around without ing it, it runs fine. over winter, i had it bored .50 over. so i thought maybe the jetting was lean. i bring it up to my garage, pull the plug, and sure enough, its white. so i took the main jet out, and brought it to my local yamaha dealer. i told them i need a bigger main jet, so for 5 bucks, i went from a 58 mikuni and bought a 60. i put it in when i got home and it still runs like crap. the carb is rebuilt and clean. is it timing? is it fuel? please help!
    Pennsylvannia
    1,147
    Sounds to me like something in the carb. I'd place my bet on it not being tuned properly.
    Central CA
    459
    A loose wire could cause "missing".
    86 250R
    86 250R
    86 250R
    85 250R
    82 250R
    86 350X
    81 185X
    85 250SX
    87 200X
    Sitting on my can can, doing the pan-o-ram..
    Oct 2005
    North Branch, MI
    196
    i was leaning towards carb problems. could a float not adjusted properly cause this?
    Dave223 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    Houma Louisiana
    388
    by chance, have you checked to see if the exhaust is clogged? sounds funny but if its clogged somewhat, it will idle fine, but miss and seem to lose power at higher rpms. Just a thought, Dave
    3leggeddog's Avatar
    Nov 2004
    i say continue to play with the jetting.try to go up another jet size.buy a 62 65 and a 68.
    Apr 2006
    Crestview, Florida
    2,429
    try turning your mixture screw in alittle. my wifes ytm225 has to be ajusted about every week.
    Oct 2005
    North Branch, MI
    196
    my fuel/air screw does absolutely nothing. i can turn it in and it will run the same way as if i turn it all the way out. it has no effect on my trike running properly. im gonna give it another try today. maybe ill have some luck. give me some more suggestions. could it be a timing issue?
    Baltimore, MD
    6,088
    If your turning the air fuel mixture screw and it is doing nothing, I'd say your carb is dirty and something is clogged. Your air fuel mixture screw should have an effect. Unless it is just the fact that your jetting is still so far off. I'd say the problem is with the carb not anything else. Wether it is jetting or dirty carb I'm not sure. Did you take your time and break you engine in? If not be careful.
    Oct 2005
    North Branch, MI
    196
    i did break the motor in. but i found the problem, i purchased the wrong pilot jet for the carb. (wrong yamaha part #) i put my stock one back in and now it runs like a raped ape. thanks for the help!
