It's time to finally start on this project. When I first got "Casper" I did a CR500 rear shock conversion. I ended up with over 12" of rear wheel travel and with the use of an Ohlins shock and custom spring, a much better functioning rear suspension.
The goal with the front fork swap is to gain as much suspension travel as possible without raising the bike so much that it's tippy. In preparation for these forks I previously added a custom 10" Douglas wheel with a 21" front tire. So, I effectively dropped the front of the bike 1.25".(difference in height between original front tire and new one)
So the goal is to end up with a ride height approximately 1" taller than original. I may end up modifying the forks internally to remove an inch or so, but hopefully not. We'll just have to see how it pans out. If I can get away from that, I'll end up with 12+" of travel in the front suspension too!
More importantly than the travel though, is that i'm after the larger diameter (stronger) forks. In MX the stock forks tend to flex alot under landing from jumps. To the point of the front tire actually hitting the pipe. (I've seen it with my own two eyes!)
So here's where i'm at so far:
250R triples are modified to accept the larger diameter forks
Front wheel and tire is ready
Front forks are modified to accept 250R axle assembly
Basically i'm down to fitting them on the bike and building the mounts for the front brakes. I'm going to use the CR500 front brake system, since the original 250R front brake line won't be long enough for the new forks, and the CR line is braided steel. The front brake calipers appear to be the same on both bikes.
