The 3wheeler 2 strokers were designed to run on leaded gas. Whats happening to our engines without using lead in the fuel? I've got a couple of cases of lead additive, just not sure how much to add.
3 CR500R's and counting. Do I really need 4???
Do I really need 9 Tigers?
Laegers ATC500R
DO NOT send any thing to whats his face (dirt-face/crasher) here on the board. What a scum bag. He screwed (stole) money from me and screwed me on my ME360 and Hondaline 300R engine rebuilds.
Lead keeps the motor running cooler and helps with added lubrication. Lead has been removed from fuel because it cannot be used in vehicles with catalytic converters, which is just about everything these days. If you buy race fuel (VP C12), it's usually leaded. Not sure how good the lead additive is. I wouldn't go overboard with it, maybe just use a little. One thing you should consider is that much higher quality 2 stroke oils are available today then when your trike was built. That in itself makes a big difference in engine longevity.
[FONT="Palatino Linotype"]~My Rides (to name a few) ~
1986 ATC250R, 1985 ATC350X
1985 ATC250R Missile (90% done)
1983 ATC185S
1999 TRX416EX
2003 Honda CBR600RR
1990 Yamaha Zuma
1985 XR80 w/100 motor
1967 Honda CB77, '65 CL77
1962 Puch 250 SGS
1984 XR350R (owned since I was a kid)
1972 Suzuki T350 Rebel, '73 T500 Titan
1964 BSA A65 (needs restored)
1968 BMW R60/2 mint original bike
1976 Kawasaki KH500 triple
Anybody have parts to trade for the above models?
i dont think the where designed to run on leaded fuel by the time that most 3 wheelers were made unleaded fuel was the common fuel w/the exception of the early 90s& 70's & that brings up an interesting point i wonder if they had hardened exhaust seats in the 70s& 90s thats really the only thing that effects the motors in pre 73 ish car motors because of the lack of the lead .....id like to hear howdy chime in on this subject
1973 atc90k1
cobra exhaust,1978 thumb throttle ,& pegs
'80 honda 110
'84 yamaha 200 x2
'85 yamaha 225 dx 4sale
'85 tecate 3 basketcase
'85 honda 200x
'02 blaster race quad getting full rebuild
'88 suzuki quadzilla sold miss it
'00 honda XR650R supermoto
Unleaded gas has been around for a long time. ATC's during their peak were all running unleaded gas. The only thing lead did was lube valves in cars and 4stroke engines.
All of the cars now have hardened valve stems and seats to run unleaded gas.
If you get a valve job done these days, they add these parts hence the phrase "unleaded heads".
Don't even bother putting lead additive in a 2 stroke engine. The oil does the lubricating.
Why wait for howdy to "chime in". It's a no brainer.
1980 110
1982 250R
1985 200s
1985 250R
1985 350X
Parting out...
1983 250R
1984 185s
PM me for parts
OK, Then how does our unleaded gas effect the 4 strokes made in the 70's?
Laegers ATC500R
Lead raises octane numbers doesn't it?
I thought it was referred to as "cheater gas" in the 2-stroke MX world.
Leaded fuel will not hurt a 2-stroke as far as I see it. Actually, I think it would be an improvement.
86 T3
84 T3
86 KX250
There never was Lead in gasoline. It was "tetraethyl lead" a clear liquid that was an octane booster. It was replaced with other chemicals because TEL caused pollution.
It makes no difference what fuel you run, im running a 1938 Chevy right now on unleaded, it could care less.
Lack of "lead" never did damage valves, they were damaged by detonation as a result of overheating and lower octane fuel.
hey, all 4 cycle atv's have aluminum heads with valve inserts, so it's not a problem.
one cylinder is not enough!!
Originally Posted by TeamGeek6
have you ever seen led additive? its dark gray. and i was allways told it will hurt your valves.
Confused As A Hungry Baby In A Topless Bar!!!
'04 Honda CRF250R
'82 Honda 200 4'sale soon
'90 and '91 Arctic Cat Prowler 440
'81 Kawasaki LTD 440 Belt Drive!!
'92 Yamaha Warrior 350
'05 DS 90
Helmet save'd my friend's life, and mine, wear one!!!![]()
Trying is the first step to failure![]()
3ww Needs an iPhone app
OK 2 stroke engines do not need lead in the fuel........Lead was added to gas to help valve stem seals (make them softer so they seal better).... seals are made of different material these days that don't need lead to help soften them ........so using a additive is a waste of cash......
On the bottle it says "valve seat anti-wear additive for low lead gasoline. Protects engines requiring leaded fuel from valve damage due to low lead or no lead fuels currently available. Prevents upper cylinder wear".
Laegers ATC500R
