Results 1 to 15 of 15
Thread: Pvl, Motoplat, Cr Ignition
    Jan 2004
    NJ
    1,646
    Will any of these make a noticable change in how my engines perform? And what can I expect?
    3 CR500R's and counting. Do I really need 4???
    Do I really need 9 Tigers?
    Laegers ATC500R
    DO NOT send any thing to whats his face (dirt-face/crasher) here on the board. What a scum bag. He screwed (stole) money from me and screwed me on my ME360 and Hondaline 300R engine rebuilds.
    Front royal, va
    2,186
    i have the motoplat for the tri-z, i wouldnt go back to a stock setup, hell, id get it for every bike i own if they made them ..revs alot faster.. no wires on the bike, just a coil and flywheel the size of a golfball
    Aug 2004
    Phoenix
    1,226
    PVL bought out motoplat. They are virtually the same ignitions. I run the PVL on the KX500. Its very high quality and made in Germany
    Jan 2004
    NJ
    1,646
    Any other serious riders or racers out there who have upgraded their ignition????
    Laegers ATC500R
    Aug 2002
    New York
    1,098
    I run a PVL on my 330 ice bike. It works well. The bike is apart for some updating, so I have a pic of the ignition.
    Anaheim
    1,270
    well as it is for a 250R, i say CR ignition... or you can go davemooreracing.com and get his cdi....
    Adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    Jan 2004
    NJ
    1,646
    Only good for 85-86 250r's
    Laegers ATC500R
    Richland WA
    808
    Quote Originally Posted by 88 Turbo Coupe
    Yes. I hopped the stock 250R system. Also put a GM HEI system off a Camaro on it.
    http://gl1200harness.tripod.com/ (hit the "Modified 250R ignition systems" link at bottom of the page)
    Theres plenty more in the stock 250R system if you know how to get it out. The stocker isnt much different from the CR.
    Quote Originally Posted by TeamGeek6
    can you possibly do this for a tri z system?
    Newfoundland
    5,280
    The flywheel size is what the advantage seems to be. Lets the motor wind up and wind down "a lot" faster then stock. I bought the KX setup for my Tecate and the flywheel is almost 2 inches smaller then stock.
    yes that has a lot to do with thoes kinds of systems. but the same results from a stock set up...???? you get the spark not the rev
    Aug 2002
    New York
    1,098
    Flywheel size is part of it, but not the only benefit. You can set the timing wherever you want. I run my bike -5 because I rev the piss out of it, so it helps the bike run cooler and helps overrev on top end. I do sacrifice some mid range power, but the motor puts out plenty of power. The PVL also has a hotter spark. If you use alcohol or a big bore motor, it's recommended (although not required) to run a better ignition.
    Richland WA
    808
    Quote Originally Posted by bryan raffa
    Yes, the Tri-Z and 250R electrical systems are the same design, the mods are the same. If you want any particulars, Email me.
    Chris, loss of midrange power may be because of loss of flywheel weight. Its there for a reason, to store torque between strokes and send it to the transmission.
    A high comp engine must have more spark voltage (at least) because a higher pressure in the plug gap takes more voltage to fire. If it doesnt have it, the plug will misfire, or timing has to be advanced earlier so it can fire when the pressure is lower, and that causes overheating.
    Jan 2004
    NJ
    1,646
    Honda should have offered a high voltage ignition kit as an option for the 300cc kit.
    Laegers ATC500R
    Jan 2004
    NJ
    1,646
    What about these high output coils I see advertised? Could this be all you really need to get a hotter spark?
    Laegers ATC500R
