This is what could happen If you don't check your counter balancer bearings. They are getting pounded everytime the cylinder fires.
83 ATC 70.
83 Tri zinger
ATC450AF
86 310-R Drag racer
ouch!! weld it up and grind it down. i love aluminum!!!
OUCH!...Not good, 200x... You redneck. LOL
1985 Yamaha 200E Shaft - New Toy / Project
1983 Yamaha YT175 - Kinda retired?
LOL, thats better then JB weld!!
The outer bore that holds the bearing race is beat out real bad the bearing rattles around in the case. I have another one that is the same way. I hope I can put a thin layer of weld around the worn bore then weld the hole inbetween. I think the hard part will be centering up to machine the bearing bore back out.
83 ATC 70.
83 Tri zinger
ATC450AF
86 310-R Drag racer
That's nasty looking.
1980 110
1982 250R
1985 200s
1985 250R
1985 350X
Parting out...
1983 250R
1984 185s
PM me for parts
