Results 1 to 4 of 4
Thread: how to wire coil and kill switch for ATC 70.
    conig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    tallahassee FL
    392
    when I dissassemebled my 70 I managed to loose my notes on how to wire these two things up. I finally came in contact with a throttle assembly(no cable) but can;t remeber how the kill switch hooks up.
    1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
    1985 honda es 250 big red.
    85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
    A trike to show up the modern utilitys
    2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
    Aug 2004
    tallahassee FL
    392
    can anyone take a look for me and tell me were the black wire goes when hooking this up? also I think I hooked the coil up wrong as Im not getting any spark and it appears the factory kill switch shorts out the coil to cut the engine off.
    Baltimore, MD
    6,088
    Just match the colors. I'm not sure which wires you have left? The green wire on the kill switch should have a round attaching point and it attaches to one of the screws that hold the coil mount to the frame. The other wire goes to its same colored wire.
    Aug 2004
    tallahassee FL
    392
    ok thats what I figured but I have two (I beleive black wires) coming from the case that were painted over when the motor was painted. then one black off the coil and one from the kill switch.
    ill try and scratch the paint off and see if I can figure it out. thanls for the help.
