Results 1 to 9 of 9
Thread: Oil-injected 2 stroke quads
    NE Arkansas
    2,344
    Do you have to get the oil injector block off if you wanted to run pre-mix? Could you just run the oil tank dry or crimp it off and run your pre-mix?
    Long story, but a friend is trying to find the culprit for a problem, and I suggested running pre-mix for a while to see if it fixed it.
    My Rags
    kloby's Avatar
    kloby is offline I have been Busted! Can you say OWNED! At the back of the pack
    Feb 2006
    Oklahoma
    253
    Yes, if your gonna pre-mix your gas, get a block-off plate. If not you'll be fouling plugs left and right. And that is the first thing i would do w/ a auto-injection. you never know when it might break and then you'll have nothing more than a worthless engine on 4-wheels.
    Dec 2002
    Kansas
    2,387
    You don't have to have a block off plate.
    All you have to do is unhook all oil injections lines and plug them off, make sure you seal off the line to the carb. Drain the gas tank and install premixed gas. Block off plate does nothing but eliminate the outer portion of the pump, so it is more or less just a bling factor thing.
    I had the RIGHT to remain silent, I didn't have the ability!
    NE Arkansas
    2,344
    Thanks Smokin.
    My Rags
    NE Arkansas
    2,344
    What is the oil injector ratio set at on a Scrambler 400, I think it's different at certain RPM's right?
    My Rags
    Washingtons Crossing, Pa.
    2,977
    I would get the block off plate kit from RCR or Hotseat Trav, it frees up a little horsepower but only if you remove the whole pump. I've always heard that they are quite inprecise, ranging anywhere from a 20 to 30:1 ratio. The real problem lies in the fact that it gets dumped in past the carb. I say dumped because thats what it is - dribbled into the in-rushing charge.
    NE Arkansas
    2,344
    That may be the problem right there. My buddy bought a left over 2000 model that had sat new at the dealor for about 18 monthes. Get a heck of a deal. He's had it for over 4 years, no problems, but it has always 'loaded up' after it idles for a minute and takes about 30 ft for it to clear out when he takes off. The quad runs fine, would sit there and idle all day long. He has tried different plugs, air filters, air screw adjustments, idle adjustments, nothing helps. I told him to drain the oil tank and pre-mix some gas and lower his plug gap to .020 to .024 and try that. Could he try that without the block-off plate? Or will it cause problems?
    Thanks,
    Travis
    My Rags
    2,977
    No problems, just plug up the pump lines and especially the nipple (or is it a banjo?) on the reed cage intake. I think though, his problem might be the one that alot of pingers have in general about idle loading - oil from the charge builds up at the bottom of the crankcase and gets caught up in the pipe/silencer at idle. My Scrammy does it too - just something I've learned to live with. A quick blast for a few yards or a doughnut or two clears it out fine. If youre in tight woods at low speeds, I just blip the throttle (like on a Banshee) every 5 - 10 seconds or so to bring on some RPMs. If it has stock clutching with a normal back shift helix/spring, he should have no problems doing this because of the slower engagement - but on mine, lag time is zero, so it'll take of if youre not careful about planning it (ie - not before a sharp turn with a 1000ft drop .... lol).
    NE Arkansas
    2,344
    Thanks again!
    My Rags
