ATC200X
Frame number JH3TB0527EC300001~
Engine number TB05E-6100001~
Engine type 4 stroke, Air cooled
Displacement 192cc
Bore x Stroke 65 x 57.8 mm
Compression ratio 9.6 to 1
Compression 142 - 170 psi
Transmission speeds 5 speed
Clutch Type Manual
Oil Capacity 1.3 Qt
Carburetion 24 mm Keihin
Starting system Kick Starter
Fuel capacity 2.56 Gal , 0.31 Gal res.
Wheelbase 47.6 in.
Overall Length 72.8 in.
Overall Width 41.3 in.
Ground Clearance 4.9 in.
Seat height 27.8 in.
Front tire 23.5 x 8 x 11
Rear tires 22 x 11 x 8
Front suspension Hydraulic Telescoping Forks
Rear suspension Mono shock
Front brake Hydraulic Disk
Rear brake Hydraulic Disk
Final drive Chain
Dry weight 282.2 lbs
Approx. retail new $1,748.00
