Results 1 to 8 of 8
Thread: 350X Front Brake Caliper-Pistons are "stuck" in there
    Jul 2004
    Baton Rouge, LA
    946
    Well as luck would have it, the front brake system on the X I am restoring was the only thing in poor condition when I got the bike. I need to replace the reservoir and may have to replace the front caliper if I can't get the pistons to come out. I soaked them in some brake fluid and wd40, I even took an air hose and blew some air in there where the brake line goes(like the manual says to do), but they still haven't come out. Anyone ever dealt with this before?
    1985 Yamaha 225DRN w/OEM headlight guard, footboards, front rack, rear rack, work light, brush guards and trailer hitch
    Howdy's Avatar
    Celina, Ohio
    10,079
    Yep, I took a new front master cylinder I had and hooked it up. Once I bled the air out the one piston came loose. Then I put a C-Clamp on the freed piston and the other popped loose.
    Howdy
    Apr 2002
    s.w. michigan
    6,498
    Hmmm,
    I was gonna see if those was frozen but didn't so I could get it back to you.
    Not that it matters really ,,, you are doing the same efforts as I would.
    The caliper from my X was a PITA to get them broke free.
    Keep your fingers clear is my best advice ,,, I was holding mine in one hand and using a rubber tipped blowgun (like you use for baloons ) and whem my stuck piston decided to pop out I thought for sure my finger was broke.
    john
    Nov 2002
    Kirkville, NY
    3,831
    I know the trick that worked on some old motorcycle calipers for my brother. He threaded the end of his grease gun into the thread for the brake line and then pumped away. It used a bunch or grease and you have to be careful or it will get all over but it worked great.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Jul 2004
    Baton Rouge, LA
    946
    Yeah I may have to try some different methods, I put some brake fluid in there then put the air hose to it but nothing yet. OH John, I got the left front fork from a buddy over here today, it had the brake caliper, reservoir, and the rare brake line guide still on it! I really got hooked up I guess you could say. The pistons are stuck on the other caliper too...I'm sure they'll eventually free up.
    Jackson MI
    1,688
    Well this might sound wrong but it worked like a charm. I just got done getting a piston out of my 250-R calipar. I drilled into the piston about an 1/8", with a 5/16 drill bit. I then used a 3/8" bottoming tap & threaded it into the hole, & twisted the piston around in the bore about 3 times then clampped a set of vise grips onto the tap & twisted & pulled the piston rite out. When I was done I welded the hole up. The pistons in the R calipar's are extremely thick. So I had no chance of drilling through it. I don't know how thick a 350X piston is so I would use the drill & tap as a last resort.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Dec 2002
    SW Alabama
    763
    I don't even play with those pistons. I hook up my compressed air tank from my paintball gun to the line hole. Be sure you point it away from anything important!!!! I set the reg at 850 pounds and shoot the air to it. Be sure to have something soft for the piston to hit when it comes out. It helps to wear earplugs at this step - the resulting pop is very loud. Then I put a soild bolt in the line hole. I put an adapter I have fixed into the hole from the first piston and clamp it in with vice grips. I hook the air to this adapter and shoot the air to it. I have never seen a piston that can stand 850 pounds of air. They will come out!!!
    Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
    3leggeddog's Avatar
    Nov 2004
    i have always heard to soak them in kerosene.don't know if it work though
