definatly check out the ETC incase the rev limiter is coming on.
also I would recomend a compression test the stock polaris pistons don;t last too well.
wicked could the oil injection be way out of adjustment like the return spring broke or something?
I would remove the oil injection cover to take a look see. and definatly do a compression test gauges are only like 20.00 and can identify alot of problems before they arise.
1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
1985 honda es 250 big red.
85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
A trike to show up the modern utilitys
2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
