Results 1 to 2 of 2
Thread: CAM Markings
    Sep 2005
    Iowa
    75
    CAM Markings
    I was reassembling a motor today and noticed that i have 2 cams, And each one has a different number on it. I have one that says 26 and the other says 27, it is a atc 110, do the numbers signify anthing as far as the grind?
    is one better for performance than the other?
    83 atc 110
    85 big red 250es
    95 Kawasaki Mojave
    71 SL70 - basket case - picked up 9/9/08
    as soon as you're born you start dying so you might as well have a good time - John McCrea
    Ontario, Canada
    457
    i'd say one is for the front and the other is for the back...the intake and exhaust would b the opposite from eachother, i'm pretty sure
    '85 ATC 250R
    FMF Fatty & Power Core
    Boyesen Rad Valve
    38 PWK A/S
    K&N w/PF (next purchase)
    LSR +4 Axcaliber axle
    LSR Duel row bearing carrier
    DuraBlue Anti-fade (to be installed)
    13/36 sprockets
    '85 ATC 250R
    Parts trike (maybe future build?)
