Originally Posted by
Jason Hall
I have built 250-R's that have had new crank, rod & counter balancer, even trans bearings & still sound like something is gunna disinigrate. I found that the gears under the right side cover will rattle or knock at an idle. Especially when the clutch basket is worn. I feel that all the slack from all the turning gears, will travel down to the crank & counter balancer gears, & make the crank & piston sound like it's knocking. I have rebuilt race quads that have been rode hard & jumped there entire life & they are the ones that knock the worst. The last bad one I did blew the crap out of the counter balancer bearings. The counter balancers job is to eliminate vibration. That is where all the slack will travel naturally. I would suggest a new piston / bore, crank bearings & counter balancer bearings. Make sure the clutch basket is'nt real sloppy.
get the hinson billit counter balancer holder and ditch the stock cast one. it's $100 of good insurance. this one guy where i live just got a year ago a 86 trx250r that was mint. like just of the showroom. the balancer holder broke and destroyed the cases
JASON LISKEY
2 = 86 atc 350x's
86 atc 250r
