Results 1 to 15 of 26
Thread: Float level adjustment
    NE Arkansas
    2,344
    86 250R
    Need some help setting the float. I'm trying to follow the directions on pg 133 of the Clymer manual, but it's hard to understand what it means. "Hold the carb so the float arm is just touching the float needle, not pushing down on it. Use a ruler and measure from the carb body to the float. 16mm."
    If I adjust it to where it's 16mm when the arm just touches the needle, it rides all the way to the top of the carb when it pushes down on the needle. This thing was leaking gas like crazy out the overflow tube. When I'm measuring I'm holding the carb at about a 100 degree angle.
    Any help is appreciated.
    My Rags
    Aug 2004
    Ab Canada
    4,368
    Hold the carb sideways pretty much and watch the contact between the floatvalve and the needle, then mesure from the base of the carb to the top of the float(technicly bottem....when carb is right side up)
    1985 Tri-Z-
    NE Arkansas
    2,344
    thanks man
    My Rags
    Oct 2005
    Pennsylvania
    863
    You can hold the carb upside down, let the float rest on the needle- Float paralell to base gasket will usually get you in the" Park"
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    NE Arkansas
    2,344
    so it shouldn't "bottom out" when the carb is upside down?
    My Rags
    Oct 2005
    Pennsylvania
    863
    No -The needle valve should hold it up--unless the needle tip is worn or the float "TAB" is seriously Bent
    Aug 2004
    Ab Canada
    4,368
    When the float height is set right to the 16mm the tab should just be touching the needle., when the carb is flipped upside down it should push the needle all the way back down into the seat.
    1985 Tri-Z-
    Richland WA
    808
    Quote Originally Posted by TravEX
    86 250R
    " it rides all the way to the top of the carb when it pushes down on the needle. "
    Congrats, you just found the design flaw in that 86 flat slide PJ.
    Hold the carb straight up, as it is when installed. Blow gently in a tube connected to the fuel line (no gasoline, of course) and hear the air come through the needle seat. Raise the float till it stops - thats the instant the needle touches the seat. That is the 16 mm point.
    Set it there and itll probably still leak. Once youve set it, DONT change it, DONT bend the float arms and DONT change the float drop tang. If its gonna leak after that, its not a matter of float adjustment and like me, youll destroy the float trying to adjust it.
    Take carb cleaner and compressed air (if you have it) and very carefully clean the fuel lines and carb. The tiniest bit of junk in the float needle will cause leakage. Remove the fuel shutoff by unscrewing the 2, 10 mm head screws in the bottom of the gas tank and inspect the fuel screen. Its probably hosed due to age. Thats enough to cause this problem. Make sure the tank is spotlessly clean and a new filter is a good idea.
    You may find that nothing will fix it, thats how mine was (86R) because the float needle seat was defective.
    A defective needle seat shows up as fuel rapidly filling the bowl until the float raises to shut off, then the bowl slowly continuing to fill. if that happens, inspect the needle end (rubber end) and look for damage. If its still springy and smooth, its probably good.
    A bad needle seat means a new carb. I screwed with my PJ for a year off and on trying to fix this and it wasnt fixable, because the seat isnt replaceable.
    I ended up eliminating the float altogether and it works flawlessly. Search for my post on it, its here somewhere.
    NE Arkansas
    2,344
    Thanks alot for your help. Going to try it now.
    My Rags
    NE Arkansas
    2,344
    Thanks TG6, that really helped me 'see' how it works and I got it adjusted as close as I could. The seat and the needle 'look' to be in great shape. I hate bending around on that tang expecting everything for it to snap off. Thanks again!
    Trav
    My Rags
    Richland WA
    808
    Good that youre making some progress. Avoid bending or distorting that float because it can bind the needle and cause BIG problems. I have a couple spare float needles if you need one. My old floats are wrecked though so they might not do you any good.
    Speaking of... there might be a way to "fix" an old needle seat... hmmm... must think about it.
    NE Arkansas
    2,344
    Well, again, thanks for the help. If you make it to TF06, we'll have to meet up, the first rounds on me.
    My Rags
    Richland WA
    808
    I C TF06 is at Haspin, that (was, anyway) an awesome place to ride. Have to try to make it if Im stil in the area.
    May 2002
    Southeastern Wisconsin
    3,658
    Quote Originally Posted by TeamGeek6
    So if a carb is out of adjustment it's flawed?
    Jackson MI
    1,688
    I'm sure there is a way to fix a bad needle seat in a keihin carb You just need a good machine shop guy. If there's a will there's a way I would'nt let a little piece of brass beat me , especially with a rubber tipped needle like a pj carb has. A Mikuni with a steel needle in a brass seat is a little different.
