Results 1 to 15 of 18
Thread: Waterproofing.
    sideshow_bob's Avatar
    sideshow_bob is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2005
    New Zealand
    160
    Waterproofing.
    Hi,I want to make my 82 atc 200 waterproof so I can go through deep water.I know you need a snorkel,what else is required??\\
    cheers.
    82 ATC 200...Getting torn down for resto/cleanup
    Looking for a "sport" trike in New Zealand..
    Sep 2005
    North Bay, Ontario
    54
    wouldent hurt to raise your exhaust up too, helps prevent stalling, and you stall with your exhaust under water, good luck getting started.
    1985 Honda 250ES Big Red
    "So, uhhh, whats that fourth wheel for anyway?"
    People who hate trikes seem to love stats. Statisticly speaking more people get hurt per year on 4 wheelers than they do on 3 wheelers, so why don't they just leave us alone?
    Feb 2005
    New Zealand
    160
    I meant intake and exhaust snorkels,shoulda mentioned that one .I mean do I need to seal any certain parts e.t.c?
    Randolph NY
    597
    Make sure your airbox cover seal, intake seals, exaust seals and recoil seals are good. (dont want water in any of them) it you do a momeade exaust stack make steady turns not sharp ones!
    good luck
    Jul 2004
    Mud hill. close to water !
    3,658
    Your 82 is chain driven so no shafts to seal up.... but do grease the hell out of the chain before you go.
    Check the tranny breather tube going to the airbox.. seal all the hoses and lines etc.
    If you wiring harness has been sliced and diced.. solder all the bad connections and heat shrink and tape them up good.
    Grease all bearings.
    Your brakes will fill with water and grit etc.. so after the run. open the drums and dry them out good. and re-oil your cables.
    Automotive GOOP ( brand name.. ) is awsome for sealing up all those things.
    add air to the tires to help floatation.
    Currently :
    Sep 2005
    Chittenango, New York
    84
    ive had some experince with this on my 200s, tire pressure is essental.
    water fun can be great! just shut it off before it flips if its going to!
    water can be fun and it can be a pain in the but.
    if you use a 200x aftermarket exhaust then you really dont have far to push the exhaust up with a snorkle.
    i havent touched my air box. because the snorkle it has worked fine for me.
    1984 ATC 200s
    1985 ATC 250sx
    Jul 2004
    3,658
    i beleive the 82 has the air box and takes air from under the seat.. and NOT up to the handlebars like the later 200 models.... be aware of that !
    Currently :
    Oct 2005
    Vicksburg, MI
    73
    Question I have wondered about with tires. Would more air help or not? It seems like more air would be denser making it heavier. Having less air in same amout of volume seems like it would float better. Almost like a vacum, but vacum pressure wouldnt work in tires. I dont really know just always wondered???
    Randolph NY
    597
    large knobies work wonders in water with 5 pounds of air in them. they float VERY well and dont do to bad in many conditions!
    Jul 2004
    3,658
    More air = More flotation.
    as simple as that.
    Try sinking a half filled ballon.. then fill it up and try sinking it again !!!
    Currently :
    Sep 2005
    North Bay, Ontario
    54
    I took a peak at my buddys 82 200 and you will definately have to redo the exhaust. His looks stock, the muffler is long, narrow and under the seat, what you'll want to do is get rid of that muffler and run pipe all the way to the back and put more of a stout cannister type muffler on. Use a funnel shaped silencer (should be easy to find for the cannister type, not so easy for the stock system) as a reducer. Put the silencer on, run a line of high heat silicone around to make the seal. Have any exhaust shop bend and elbo and an up pipe on the small end of the silencer, another 90 or even 180 degree bend at the top wouldent hurt eather. Also, for added stability weld 2 ams onto the up pipe that can be mounted to the back rack. The reason for using the silencer is that you can take the whole system off in a matter of minutes with a screw driver and a pocket knife if you want to do some hard riding without having that tall pipe swinging all over the place, and you can put it all back on in the time it takes the silicone to dry.
    As for the tires, yes, more air=more float, but the 200 is a light bike, and if it floats too easily it will be unstable in deep water, If your talking about sinking it to the point where you need a snorkle I wouldent go more than 5psi unless you're a heavy guy. Once you have everything sealed and snorkled, you can run a lower tire pressure and allow the bike to run on bottom so you get more traction and stability.
    Feb 2005
    New Zealand
    160
    I was thinking,I would make a snorkel exhaust system like an exhaust stack on a truck.I just want this thing to go anywhere.
    Apr 2002
    s.w. michigan
    6,498
    hmmmm
    Just how deep you plan on getting ??? You might want to think of your breathing plans too
    john
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by jeswinehart
    john
    He might need to borrow your scuba gear. lmao
    Howdy
    Jul 2004
    3,658
    Weld up dual rims in the rear and mount some floats on the front forks... go pond diving !! lol..
    Currently :
