Thread: Always replace the left crankshaft bearing??? (350x)
    Minnesota
    784
    In the 350x shop manual it says to always replace the left crankshaft bearing when the crankshaft is removed from the left crankcase. Any idea why this would be? Also they say to remove the crankshaft from the left crankcase with a hydraulic press. Do I need to use a press or will a rubber mallot take it out? Or maybe a metal with a piece of wood as a buffer? I'm not in the tear apart stage of my 350x but I'd like to get info before I get there within the next few months. Thanks.
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,238
    man, you would think someone with that many 350x's would know the answer to that one!!!! i would beat it to a frazzle with a 4lb. then cus at it some more then start pounding some more!!!!
    (JESSE IF IT SAYS TO USE A PRESS IT PROBABLY BE A GOOD IDEA!)
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    Ive never had to split the cases on a 350X, but if the book says so? If it takes a press to get the crank out of the bearing.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    Jun 2002
    Mississippi
    2,552
    on a 250r you can heat the case around the bearing with a propane torch, then just pull it apart. when you pull a case you put a lot of side load on a bearing which is very bad. i would bet that is the reason they replace them. i once replaced a case half and reused the old bearing, now i have to resplit it because i did not want to spend $40 on bearings :oops:
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    The left but not the right?? Must be that the left is a press fit and the right is a slip fit???? Either way always use a press, and always replace bearings that aren't fun to get to i.e. main, tranny etc. Your time is worth something!
