hey i got a 86 honda bigred 250 and i was just woundering were the one way bearing was at. i need to replace because my bike will not cetch kicking over and slips out of gear going down hills. any info will be helpfull. Thanks.
I don't think the one way bearing has much to do with any of those problems.
I would be thinking along the lines of being reasembled wrong and or damaged shift forks/kicker gears.
What is the history of your bigred ,,, ?
Welcome to 3ww ,,,,, john
John, John, John, The one-way clutch could cause these problems.Originally Posted by jeswinehart
bigred_boy, let me ask a few more questions.
#1 When you shut the motor off do you hear anything?
#2 Have you tried pull starting this machine ( with another machine )? If you have did the motor turn over? Or did the wheels turn but the motor wouldn't turn over?
#3 When you try to kick start it does it try to catch and then release? Or does it slip all the time?
#4 You say it kicks out of gear. Does it actually kick out of gear or does it want to roll faster down hill, and then seem to be back in gear when you give it gas ( without touching the shifter )?
#5 Have you done any work on the motor lately?
The answer to these questions should either confirm the one-way clutch going / or being bad. Or it will point to another problem ( s ).
Howdy
We shall see i reckon. I'm still leaning towards something other then.
Now we gotta help him fix it
john
I put all my money on it being a bad one way sprag clutch!
Mine is the same and has all the symptoms that Howdy described.
I beleive the sprag unit is embedded into the centrifugal clutch. It prevents it from spinning backwards.
What could be a bad outcome if one does not get around to fixing this sprag clutch Howdy?
Matt
1980 ATC 70 Needs Restoration
1985 ATC 250es Fully Refurbed
1986 ATC 350x Mint Original
If you fail to fix a bad one-way clutch or sprag ( same part ) you risk the possibility of trashing your electric starter and the 1st reduction gear that mates up with it. You might ask: How can this happen?: The one-way clutch is a mutli used item. 1st off it works sto engage the kickstarter, thus getting the motor to turn over ( for starting and such ). 2nd, it also works to ekep the engage the motor when coasting down hill ( using the motor as a brake for slowing the machine down ). 3rd aand I consider the most important thing is that the one-way clutch works to keep the motorf rom turning backwards when you turn it off. What happens here is if the motor is happens to be on the wrong stroke when shut off it could turn backwards too far and engage the starter gears on the left side. If the motor turns backwards too far It will destroy the electric starter gear and the splines on the starter. I have seen 5-10 machines with this problem. Can you wait and fix it later? Well look at it this way: A one-way sprag / Clutch will cost aprox $60-$85 plus a gasket ( $10-$15 ). I estimate $70 to $100. If you do it yourself. It sure beats spending $200 or more to replace the extra parts you trashed while saving money now.
Ultimately the choice is yours to do it how ever you want. For me I know what way I will go in the future if I have this problem. The money I save from not having to replace a starter and gear will be used for refreshments.
Howdy
I do know they are exspensive for bearings ,,, but cheaper then all the componets they can take out in the long run.
I am a hoping big_redboy comes back with a reply. I still think his trike has tinkering history.
john
hey guys well my problems are, when i kick the bike over it doesn't catch. also when im going down hills it sllips out of gear, like its in neutral but when i give it some gas it comes back into gear. and when i go to jump start it and put it in gear it just turns the tires and doesn't turn the motor over. thanks guys for the help.
Yep, just as I suspected one-way bearing has wore out. Time to replace it.Originally Posted by bigred_boy
Howdy
It seems my sx might be having similar problems - how exactly do you replace this?
It is in the centrifical clutch. Item #25 on this bikebandit link.
http://houseofmotorcycles.bikebandit...e~ATC250ES.asp
john
so it is my one way bearing that is gone? and is it hard to take the clutch apart?
No it ain't too hard to replace the bearing. The nut holding the clutch on is left hand thread.
If you don't have a manual ,,, pm me your mailing address up there in Canada and I'll copy out of my manual tomorrow and send you the copys.
john
Hmmm.... looks like i'm gonna have to get into this job fairly soon myself... doh.
I plan to install a new clutch while i'm at it.. anyone recomend " Barnett " brand ?
Currently :
84 125 M - The Mini-SXnot running yet. but won't be long.
ok took it all apart yesturday and i found out that it is the oneway bearing that is gone. thanks for all the help. very easy job.
