I have this little VCR that plays 8mm camcorder and Hi8 tapes. Its like a $500 piece of equipment I got for $70 off of ebay(for a reason, evidently). I emailed the seller before I bought it and asked if it worked, they replied it did and they had been just using it recently.It seems to work, other then when I push play, it instead fast forwards. While its doing that, you can hit pause and see the picture fine. Stop, eject, re-wind, ect all work fine. Sometimes, if you play>pause alot it will like freeze up and wont do anything, then I just eject the tape and put it back in and it works fine. I tried looking around on the sony site for some info but couldn't find nothing. Its probably 15 years old or so, the model is CVD-1000 and like I said its made by Sony. Does anyone know where I can download an owners manual, or even better a service manual? Any ideas on what might be causing the problem and how to fix it? I want to get this thing fixed so I can copy down Nathan's (03OrangeShee) video from Haspin and get it copied down onto DVD or on the computer where I can start editing it but this has me screwed up.
I'll take it to a TV shop or something if I have to but I'd like to fix it myself if I can. I've already had the cover and front panel off. All the wires going to the front buttons seems to be in OK shape and nothing is disconected or shorted out from what I can tell. Theres a little circuit board the buttons themselves are soldered to and then the wires plug into some sort of connector where they are soldered in and then ran back into the machine. Help me!![]()
