Results 1 to 15 of 20
Thread: What is the best rear end oil?
    springville, PA
    6,185
    I took a look at my rear end oil tonight in the SX and found it to be whiter than milk so right now it is draining. What is the best rear end oil to use?
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Jul 2004
    Mud hill. close to water !
    3,658
    A bottle of honda brand hypoid oil will last you a very long time... so far soo good in mine.
    I've also used canadian tire " Motomaster " brand.. no probs.
    I've found it easier to simply remove the fill cap.. and place an oil container under the diff.. and then pick up the front forks and ballance the trike on it's rear wheels.....
    quicker than removing the diff cover place and drain screw..
    Currently :
    springville, PA
    6,185
    ah yes so true. I just jacked up the front end and am going to let it drain tonight and clean it out tomorrow.
    Nate
    R.I.P HRR
    Jan 2005
    south manitoba
    273
    if the oil is white you'll probably end up by dumping it out a few times before it stays clean...but on the bright side it hardly uses any oil, a few onces.
    1985 250sx.
    1991 trx 200,1500 superwinch,snow plow(hers)
    1985 125trx. kids toy
    05 baha 90 mini quad
    110 atc (just picked it up)
    garmin map60c
    Mar 2005
    Alberta
    503
    If it's just milky, it will probably clean up with a few changes. But, if the water started any of the internals to rust You'll have to do it several times. Short ride, change it, short ride, change it......
    I had a DX diff that the oil looked like chocolate milk when I got it. I'll bet you I flushed that damn thing with at least 3 gallons before it finally came clean. I even flushed it with diesel, gasoline, thin hydraulic oil & numerous types of gear oil. Used a squirt can with a flexible spout even. Hard to believe that something so small could have had so much crap in it.
    A whole bunch of trikes.
    Brandon, Manitoba
    2,209
    how much do you put in, manual say 130 ml or something.
    oddball3's Avatar
    oddball3 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2004
    New Jersey
    224
    We used 75w-90 synthetic gear oil in my dads SX. Only because thats what we use in our snowmobile chaincases.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1985 200x fixer upper
    1979 110 PARTING OUT
    1984 70
    http://www.hardcoresledder.com/forum...post&id=155447
    '97 ZRT 600 drag sled
    '97 ZRT 600 trail sled
    '98 ZR 440 sno-pro(wifes)
    http://www.hardcoresledder.com/forum...=post&id=79401
    Mar 2005
    Alberta
    503
    Quote Originally Posted by Yamahauler
    Yeah, a 130 ml in the DX. I think my SX was a bit less, 110 ml if I remember right.
    I use synthetic 80-90w GL5 Hypoid gear oil, BTW.
    Jan 2005
    south manitoba
    273
    don't waste your time measuring the oil before you pour it in. put the bike on level ground and fill it up till it barely spills out the rear plug, all it takes is one quick squirt. to save time put the rear on a block and run the bike through the gears, let down drain/ refill / back on the block run through gears / let down / drain.......bla bla till the oil is clear.
    1985 250sx.
    garmin map60c
    Phoenix, AZ.
    6,719
    Nobody went for the obvious joke and said Astroglide?
    Las Vegas, NV.
    2,483
    Quote Originally Posted by Dammit!
    Either no one else has a kinky sense of humor, or they were too emabarrassed to admit that they had knowledge of rear end lubeage. Either way, you're a brave man for admitting it ! I'm gonna give that one 2 snaps up in "Z" formation.
    NASHVILLE
    514
    I was thinking WET PLATINUM would be the overall LUBE winner. Astroglide has the word AST in it. I can't type anymore. The laughter is too much!!!!!
    Current Rides:
    All Red's!
    Mar 2005
    overton, PA
    5,257
    lol when oil gets milky i put tatf fluid in for the draining it kinda draws the moisture out and usualy onlyahve to chancge it once or twice. and then i use a good hondaline hypoid gear oil or i sometimes get the big bottles from pennsoil to put in my bogger sx b/c that oil getsd chained alot!. but in the manual i have says to checked anualy and changed every2 years and recomended lubercant is a good quality sae 80 hypoid gear oil and the final drive capacity is 100 cc(3.38 oz.) if thats any help.
    springville, PA
    6,185
    Well i got the oil tonight ( cant remeber what the hell it was but it was hyploid 80w-90) and used about 4 oz (marked it on the bottle before I started pouring. Ill change it again tomorrow after it sets the night.
    Nate
    R.I.P HRR
    Dads is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2002
    Richmond, NH
    219
    If you run the trike and then check the diff. oil , it will be white with air bubbles.
    If it sets over night and is white you have water in it. And water only gets in one way through the drive shaft seal.
