Page 3 of 3 FirstFirst 1 2 3
Results 31 to 40 of 40
Thread: 2 Stroke Oil Makes A Big Difference
  1. #31
    Nov 2002
    Chezzetcook Nova Scotia
    1,836
    Well to the mixing ratios. I have a 2 stroke that runs to 10-1 with 30 weight oil. And I run 20-1 in my tecate. When you have more oil you have to giver more, to prevent fouling lol
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
  2. #32
    Apr 2008
    NW, IND.
    842
    When I break an engine in, I'll use Golden Spectro(not a full synthetic) at 32:1. After it's broke and when it's warm out, I'll go to a syn/castor blend. (Klotz, Maxium927, Redline) at 40:1. Been using 927. I called(Maxium) and asked them what the percentage of castor oil is and it's 60%. I don't think castor burns well in cold condtions, more of a racers oil. Beets
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
  3. #33
    springville, PA
    6,185
    Quote Originally Posted by beets442 View Post
    I believe castor oils separate from the gas once your around 35 degrees.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
  4. #34
    Dec 2002
    Spruce Pine, Alabama
    1,263
    Quote Originally Posted by Tri-ZNate View Post
    Maxima 927 states on the bottle that it may seperate below 35-degrees with some race gas or Aviation fuels with a specific gravity below 0.735. I've ran it with 87 octane pump fuel at 29-degrees riding in the snow a few weeks ago with no problems.....of course I did shake my Tecate pretty hard before I cranked it, just to be sure
    '84 ATC70.....my 8-y.o. son's ride
  5. #35
    Nov 2006
    southern oregon
    2,338
    Are you guys changing oil ratios when you are comparing types? I dont see what there is to gain by going leaner on oil ratio.. Rich is the way unless you are oil fouling plugs.. Which is seldom the case.. I have never had any issues on any machine using 32:1.. Sure some people use 40 or 50:1 with decent results but what is there to gain? Remember a fast guy on a rpm machine needs more pre-mix oil than a slow guy on lesser rpm engine.. So what works for one guy may not work for another... I use Super techniplate or 927 at 32:1 powervalves or not...
    2-stroke lover
  6. #36
    Jan 2008
    South Louisiana
    60
    I currently use klotz super techniplate at 32:1 in my 83 300r. you guys think I would i see a difference if i used the r-50 synthetic? any mods necessary for using synthetic pre mix?
  7. #37
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    Quote Originally Posted by iamschme View Post
    Super Techniplate IS r-50 with a 20% castor blend. its a better oil all around than the r-50 for most applications.
  8. #38
    May 2007
    Coshocton, Ohio
    1,815
    Quote Originally Posted by cr480r View Post
    You nailed that one down pretty well. The only oil in the crankcase of a 2stroke is what it gets from the fuel/oil mixture. In my book the more oil you can get away with in the mixture the better. I would go no less than 32/1 no matter what kind of oil you use.
    Appalachian American Racing
    the home of
  9. #39
    Jun 2006
    Illinois
    491
    I agree with the 32:1 mixture also. It seems to be a good balance.
  10. #40
    Dec 2007
    Indiana
    235
    If you really want some good 2 cycle oil, use the stuff you can get from Casey's gas stations. Great stuff lol i run it in everything 2 stroke. I never run above 40:1 and i never fouled a plug on my 250R.
    -Phil
    Rides:
    1985 ATC110
    1983 ATC70
    198? ATC200X (sold for $300) (bought back for $50)
    1984 200M
    Past Rides:
    1981 ATC250R (sold for $700)
    2003 Arctic Cat 500 4x4 Automatic (sold for $1000 + a 87 TRX250 Fourtrax)
    1987 TRX250 Fourtrax (sold for $600)
    1978 ATC90 (sold for $75)
    Many Many Other 90 and 110s
    198? Tri Moto 125
    And several other misc, other trikes.
