hey all, I have a 84 trx200 and the stock fron tires are 21-7-10, and I was wondeirng how it would effect the steering if I put 25-12-9 on the front. I know I have to do some modding, but was wondeirng if in the end it woudl even be worth it.
1984 Honda 200es Big Red
Bored out
Aftermarket Exhaust
K&N Air Filter
Unfortunetally Blew the engine and got in a bad accident![]()
1984 Honda 200e/200es pieced together (parts machine)
1984 Honda TRX200 Works, but also needs work
i have to ask why?![]()
those big tires won't fit on those rims. by the dimensions you posted a 9 inch tire will not fit on a 10 inch rim.
if you did put tires that big on there first off there 2 wide and next there gonna be to heavy for that to push.
Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
My Feedback
http://www.3wheelerworld.com/showthr...k-for-sblt500r
I agree, plus it will rub on your plastics and you will probably not be able to jump it well. Also you normaly put the bigger tires on the back. I think you got it backwards.
Rest in peace Rex Carlson
if you just want a taller front tire get either a 22x7x10 or a 23x7x10. you'll have more choices with a 22 inch front tire. thta would give you a littlr more ground clearance in the front plus help it steer better.
My Feedback
I was just doin this for fun. I have rins for these tires and everthing. I know it wouldrub and the plastics have to be held back. It looked cool, butI didntthink it would be practicle.
Bored out
Aftermarket Exhaust
K&N Air Filter
i don't doubt that it would look cool.if you get them on there you'll have to do the same to the rear. just so it looks even.
make your own custom lift kit so the tires clear.![]()
My Feedback
Ya I put 22-8-10's on, and it looks alot better
Bored out
Aftermarket Exhaust
K&N Air Filter
Originally Posted by sblt500r
Lmao... It don't look cool at all!![]()
who has a grizzly with 25 inch tires on it?Originally Posted by chrisr200x
hmmm, you must think it looks cool!![]()
My Feedback
25" gbc dirt devils to be exact!The fronts are skinnier compared to the rear tires... Like the good lord intended!
BTW... I see no three wheeled vehicle in YOUR signature anywhere???![]()
you just noticed that? i'll half to try and aquire one.Originally Posted by chrisr200x
i could write down the past ones i've had? or just delete the whole sign completly.
the fronts are skinner to make the steering easier. all quads are that way, until someone does it on purpose. probably make it handle like crap though.
My Feedback
I figured handleing would be crap! looked real different with 4 25-12-9's. Had realy wide stance. Looked unique, deffinetally not a thing I'm going to do. The 22-8-10's on the fron are nice.
Bored out
Aftermarket Exhaust
K&N Air Filter
I bet that thing willl float with 4 tires that big on it. you could just float across the mud holes maybe.
I've seen trowling motors on serios mud quads before so who knows.
1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
1985 honda es 250 big red.
85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
A trike to show up the modern utilitys
2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
