Does any year model Banshee swingarm bolt up on a Tri Z?????????
85 Tri Z 250
Boyesen Power Reeds
+4 Westcoast Swinger
6 speed tranny
Drag ported & polished
Pro Lite Piston
DG Nationals Pipe
Too many small mods too list.............
Nope. With some custom fabrication im sure it will fit.Originally Posted by Semo Tri Z
1985 YAMAHA TRI-Z 250 sold
2006 YFZ 450
i have a banshee swingarm if you want it liek 10 bux plus shipping.
Originally Posted by twgranger
It would take less fabrication to build one from scratch. The Z motor fits into the swingarm. The Banshee isnt even close. The Blaster is closer, but it makes no sense since the TriZ swingarm and rear end assembly is much more advanced than the Blaster, and Z swingarms dont sell for much.
just get one made, or take a stock Z swinger and have it stretched out.
Current Bikes
02 Drag/Dune Banshee
84 ATC 110 -4 SALE
84 200S- all original other than tires!
85 Tecate (need motor)
Former Rides
03 660R- R.I.P.
85 Tecate 3 Nice!- Sold
82 250R -Sold
I'm not so sure the Banshee swinger wouldn't work with minimal mods. I've been curious to see try this myself, before.
Since both bikes use the same suspension linkage, it would seem that you could just mark and remove the center section of the Banshee front tube and install some bushings. You would have to use all Banshee rear carrier and rear brake caliper to make this work as well, but I think it might work!
The 85 and 86 Z's have different linkage. What year does the banshee share with?Originally Posted by Derrick Adams
The linkage looks the same, but they are different dimensions. Neither the old style or new style Banshee matches mine. The Warrior is closer but it doesnt match either.
But when its all said and done, and you hack the center chunk out of a Banshee swingarm, and fabricate it to work, what do you gain? I guess my question goes back to the original post, in asking, why do you want to put a Banshee swingarm on a Tri-Z?
