Results 1 to 13 of 13
Thread: What makes a 250sx engine hard to start...
    Jan 2004
    66
    What makes a 250sx/es,trx250 engine hard to start after it's warmed up a little? Brother has an '85 trx250 that is really hard to start after it has been warmed up. His 250sx was the same way. I think it's the coil going...or is it a carb issue maybe?
    Any help appreciated - thanks.
    Richland WA
    808
    Can be anything from loss of compression, fouled or fouling plug, weak ignition (CDI or electrical connection affected by engine heat) or carb too rich. A combination of weak ignition and rich carb is what to expect. A cold engine needs more fuel to start so it follows that if its rich, itll start easier cold.
    Try getting it hot (like where it is hard to start) and throw in a new spark plug. Do it quickly so the cylinder doesnt have much time to cool. If that doesnt show anything, check the carb jetting and fuel level in the carb bowl. And look at the spark arcing against the spark plug, it should be white.
    Jul 2004
    Mud hill. close to water !
    3,658
    Well.. funny you ask cuz my SX has just recently started doing this .
    I found that opening the throttle just a tiny bit will help it fire but during the last few trips once hot.. just like you mentioned.. it will start but not easily like it should.
    Anyone else ???
    Currently :
    Aug 2004
    East Central, Missouri
    546
    I was hoping this was a cold start post.......
    Mine takes a little while to start cold, even using the choke.
    You crank for about 20-25 seconds before it'll fire when it's cold.
    But when it does start, it purrrrrs.
    And hot start?
    You so much as BREATH on the start button and it fires right up.
    Gotta love these 250SX's, though.
    What a cool ride.
    nimda78's Avatar
    nimda78 is offline At The Back Of The Pack Arm chair racerFirst time rider
    coeburn va
    177
    with the age of these toys, my experience is after the cylinder heats and expands, the rings cant swell enough to make up for wear. and is simply at a loss of comression. electronics for the most part rarely fail. even after 25yrs++
    james
    -1983 Yamaha YTM200K chain drive -3rd owner! -UNI dry foam performance filter /w wet outterwear -RM 125 2" rise steel handle bars in black powder now - bent from a rolloverCustom 2" round LED tail light /w stainless steel trim in aluminum mount Custom polished aluminum diamond plate rear fender brace with Stainless steel hardwareStainless steel Torx mudflap bolts Custom ONAN vtwin muffler TOUGH sound
    -1986 kx80- S O L D
    springville, PA
    6,185
    Mine used to do it and since the electric start doesnt work I had to kick for a little while before it would start. Try holding it full throttle for a kick, then after 2 kicks it should start. Make sure the choke isnt on either
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    conig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    tallahassee FL
    392
    depending on the year or if it was added. There was a cold start "option" I don;t know if thats the correct way to decribe it. It was basically the smae jets that came on the 87 carb but it was a larger pilot jet I beleive. I have seen it searching before on here.
    If you have it it would explain some of your scenario. My red has it and it fires first kick when cold and then I have to crack the throttle alittle bit when hot. I don;t run a battery becuase I keep loosing them to the trail.
    1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
    1985 honda es 250 big red.
    85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
    A trike to show up the modern utilitys
    2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
    Jul 2004
    3,658
    Either way... mine used to fire right up warm or cold.. but lately has been giving me problems starting when hot.... only started lately.
    I would say it started since i last replaced my plug now that i think of it ......... might try another one for fun.
    Currently :
    Aug 2004
    tallahassee FL
    392
    would valve adjustment affect jetting?
    Nov 2004
    Fort Kent, Maine
    2,132
    Holding the throttle slightly open when starting a warm engine helps big time on my Big Red. (250es)
    In 1985 there were a few 250cc models that had a defect in the carb, causing a cold start problem. Honda produced a "kit" to fix this problem, but not everyone brought their trike to the deasler to have the "kit" installed. These kits are VERY rare nowadays.
    I have no clue what causes the problem with the warm starting.
    Phil
    '85 350X-The Flagship
    Speedo, Chrome HL Guard, Rubber Steps
    DG Chrome Power, 6-Pack Rack, White Bros Skidplate, 400ex Carb
    '85 250ES Big Red-Working in Style
    Many Hondaline & Aftermarket Add-ons
    '84 250R-Old School Racer Project
    Too many Accessories to List
    '82 200E Big Red-The Tractor
    Rubber Steps, Tripmeter
    '85 250SX-Rider
    Various Accessories
    '13 CBR250R & '05 CBR600F4i-Road Toys
    Yoshi Slip-Ons & Fender Eliminators
    Jan 2004
    66
    Quote Originally Posted by nimda78
    james
    I thought of this as well, but wouldn't it smoke a lot more onced it's warmed up? This bike does not smoke at all. It just seems to run a little choppy and is hard to start when the engine is hot.
    "In 1985 there were a few 250cc models that had a defect in the carb, causing a cold start problem. Honda produced a "kit" to fix this problem, but not everyone brought their trike to the deasler to have the "kit" installed. These kits are VERY rare nowadays."
    I had this kit on my '85 Big Red. It really imrpoved cold starting - I never had a problem starting it when it was warm either - it was actually easier to start.
    I keep leaning towards an electrical problem. I'd like to get my hands on it and try a spare coil or spare plug - see what that does.
    Thanks for all the replies.
    Feb 2005
    Oregon
    772
    My SX is harder to start cold, but when it is warm ill open the throttle just a hair. Now when my tri-z or Tecate gets warm i always have to opean the throttle a tad to get them started.
    1986 310R
    1975 F150 4x4
    1975 F250 4x4
    1968 F100 2wd
    2001 Dodge 1500 4x4
    Aug 2004
    546
    Thumbs up That makes sense now.....
    Quote Originally Posted by conig
    The first thing that came to mind with my cold start issue is a lean condition.
    The "cold start option" you describe fattens things up a bit.
    But fattening up the cold start produces a wee bit fat hot start, necessitating the "cracking of the throttle for hot starts".
    Interesting, VERY interesting.
    I'll try and find the '87 250SX jetting combination.
    That would be easy to duplicate.
    Thanks for all the input, folks!
