ok my 200x is spraying oil from the exhaust manifold like crazy, its covering the front of the frame and the front fender with oil. and its smoking like crazy from burning the oil. it smokes worse than prolly five two strokes in a closed building.
why would it be doing this?? i do not have an exhaust gasket but i wouldnt expect oil to be traveling like this...its so bad that my silencer is covered in oil, * could probobly stand behind it and get sprayed with oil.
i just replaced my valves, but it smoked ** that, i thought it was a bad exhaust valve causing the oil. my exhaust valve was bad when i pulled it but it didnt fix the problem... my motor is off a fresh rebuild but its been running long enough to seal the rings i would think...or it would atleast be using less oil than this...
not running yet. but won't be long.
