Results 1 to 15 of 60
Thread: lETS SEE PICS OF ARTERMARKET EXTENDED SWINGARMS
    Apr 2003
    Central New York
    1,860
    I would like to see some aftermarket swingarms and the Brand Name. I really dont know anything about Three Wheeler Aftermarket Swingarms. It seems to be the most sought after Part for a Sport Trike.
    Im looking for an Aftermarket Extended Swingarm for my Tecate and I think the stock swinger is like 17" so I would like an extra 2". How hard is it to find a swingarm for a 84-85 Tecate?
    84-85 Custom Tecate
    1986 Honda 200X Daily Rider
    2006 Suzuki King Quad
    Jan 2005
    Great Bend
    704
    these are pretty shatty edited pictures put these are a few pics of my PK swinger i got off ebay for $180. I really haven't done a hardcore measurement on it but it's either 2.5" or 3" over stock. it uses all the factory suspension linkages for the 83-84 250R's
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Bartlett TN
    3,083
    Here is a PK(orange/red) and a Westcoast(white). The PK is a +1 and the Westcoast is a +2. I have the PK powdercoated to the factory color and put it on my flat track 250r now.
    86-87 Tecate ROCK!
    May 2002
    Texas
    2,670
    This evening I'll post up some pics of 84/85 KXT WestCoast swingarms I used to have and the WestCoast on my Tri-Z.
    You might want to look into an 86 KXT swingarm. They are aluminum and I think they are an inch or two longer than stock 84/85 swingarms. I'm pretty sure the 84/85 carrier will bolt in. If not you can run the whole carrier, axle and hub assembly. remember you can't use 84/85 wheel hubs on an 86 axle, but 86 and 85 hubs are the same bolt circle so you can get there. And probably get there faster and cheaper than hunting up an aftermarket swingarm. I know there's a couple guys on here that have done this.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    Aug 2002
    691
    there is my 86/87 t3 calfab, I have no clue how much extended it is, I haven't measured it yet.
    on this R I have a stock length calfab, I don't have any good pics of it yet, I'll take a better pic of the backend of it later on, of course there is one on ebay right now, but mine is made alot different than it is, I suppose because it's an 85, and mine is for a 86 they changed the shock mount design some, and strengthened it alot.
    As to your question, tons of companies made swingers for trikes back in the day, westcoast, calfab, p-k, champion, trinity, durablue, dico, dg, franks, white brothers, those are a few I can think of right off the top of my head. Out of those, the westcoasts and franks seem to be alot more common for tecates. I know someone selling a westcoast for a 84/85 t3 in fact.
    73 cr250m elsinore, 85 atc70, 85 250r flattracker, 87 250es bigred, 86 tecate, 2004 gas gas de300
    Fresno Ca
    2,695
    Heres the westcoast i just sold, its for an 81/2 R
    May 2002
    Texas
    2,670
    Hey Pumper, I'll trade you my Tri-Z for that KXT Cal-Fab.
    Well, maybe not.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    Aug 2002
    691
    LOL jeb, hey I wasn meaning to tell you, on your Triz you said you wanted a 10" front rim setup. What is the bolt pattern on the 86 triz front rim? The honda pattern is 4 on 170, if the 86 triz is that size or smaller, you could have douglas custom make a rim. That's what I'm going to have to do for mine because the mitchell I've got on there now is bent slightly. If they are custom drilling it, might as well be whatever pattern you need. I think they charge about 50 bucks, then a 30 dollar custom fee.
    CUYAHOGA FALLS, OHIO
    1,242
    Nice
    Were Can I Get One For My 84 R?
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
    2011 KAW SXR800- 35YR EDITION
    05 HERITAGE/SPRINGER/SOFTTAIL
    Lots_Of_Nothing's Avatar
    Upstate NY
    2,665
    Hey Pumper, I took this pic right after that other one. It shows how beefy that calfab is. Also shows a bunch of other goodies on your bike.
    I have more pics of it, I took like 10 or so when I first saw it, and it was clean... Problem is I cant find them right now.
    May 2002
    Texas
    2,670
    I always liked the way CAL-FAB covered all the air gaps in the swingarms and ran the ribs back from the linkage mounts.
    Pumper, all that 250R needs is my R's screen number plate on it. (which is just like ScottZJ's)!
    Now I'll gladly trade you the number plate for the KXT Cal-Fab!
    I think my Z would be cool mixed in the pics with you guy's race replica Rs.
    Thanks for the tip on the rim. I think though, 85 & 86 Tri-Z front hub bolt circle is somewhat bigger than the Honda's. The key is if the hub will fit in the bell of a 10" rim.
    Does anybody know if Douglas will anodize for you too?
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    Aug 2002
    691
    Haha jeb, I've got a numberplate just ilke scottzjs' it had one little cracked place but it's plastic welded where you can't hardly tell. I like the look of that ufo plate better. The only place I've seen others is in the old race pics in my old mags. But I do think the ones like you and scott have look better than the maiers do.
    Apr 2003
    Central New York
    1,860
    Aftermarket Swingers
    Thanks for the info, that 86 Calfab that 86Waterpumper has is cool. I would like to see the top of it to see how its shaped. I also would be interested in knowing how much you friend wants to sell his swinger for. Im looking for 2" extension because it seems thats all I need for where I ride.
    I take it all of these swingarms go for big bucks.
    84-85 Custom Tecate
    Houston,Texas
    1,044
    I have a rare aftermarket ATC 90/110 swingarm. From the best of my knowledga it bolts up to a xr 50. Can we say, "conversion"? I am not sure if this post was for aftermarket Tecate swingers or all aftermarket swingers, but I figured I would post it anyway. Can someone resize the pic for me? Thanks.
    BTW, it is for sale.
    "I am going out of this world.....the same way I came in...screaming and covered in blood."
    Jan 2005
    Columbus, Georgia-Mid Dixie
    5,301
    Does this count?
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    83 YTM 200L For sale,
    82 Tri-Zinger 60 For sale,
    8? YTZ 80 Conversion,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
