Hi Guys what would be the effect of putting a 36t sprocket on the rear and a stock 13t on the front of a 250r? I bought a new set of sprockets and have just dicovered that the new rear is a 36t I used to run a 39 t x 13t Thanks
Each Gear Will Be Taller!
3-85 ATC 70
86 ATC 250R
86 WETBIKE
01 KX250
2011 KAW SXR800- 35YR EDITION
05 HERITAGE/SPRINGER/SOFTTAIL
Hi Max will it be slower top end using this set up? am i better off sticking with the stock 39tx13t the engine is 40tho over (wiseco piston) with boyesen power reeds thanks Stacey
If You Trail Ride. Id Go Back To Stock. 13/36 Will Definately Give You More Top End. You Wouldnt Barely Get Out Of 1st In The Trails.
3-85 ATC 70
86 ATC 250R
86 WETBIKE
01 KX250
Trails is what I ride most I think I,ll take your advice and go back to stock Thanks a lot Max !!!!
mine is all pepped up like yours. all i do is trail ride. i use a 12/39.
3-85 ATC 70
86 ATC 250R
86 WETBIKE
01 KX250
I,m in the middle of restoring it I,ve just had a new piston kit shipped over from the US and ive just sprayed up the frame and ive had the swingarm and axle zinc plated in a yellow/gold colour it looks the bizness so all ive got to do is put it all back together!!!
I will get some pics posted on Monday hopefully, I went to get my swingarm from the platers today but they closed early so I,ll have to pick it up monday instead, no probs as I,ve plenty to do I,m going to have a crack at rebuilding the forks I,ve already put new seals in but I,ve got to put oil in yet so I,ll have a play this afternoon if I can get of the forum!!!!
