Thread: replacing clutch
    Nov 2002
    1,189
    replacing clutch
    on a 225dr, what parts do you need, like frition plates, what else? also, any tips? if i gun it, it will slip, then wheelie. i want to see if the clutch is doing that.
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
    Nov 2002
    1,189
    also, it has been sitting for a few years. if i change the oil, will it help it?
    My Rides
    Yamaha 200E
    Nov 2002
    1,189
    sorry bout that, it has been siting for a few years, but before starting it, i chnged the oil and filter
    My Rides
    Yamaha 200E
    Howdy's Avatar
    Celina, Ohio
    10,079
    Let me give you some information to help. My opinion is at the bottom.
    In the 225's there is 2 clutches. There is a centrifical clutch and a manul clutch.
    The Centrifical clutch is the one on the crank. It engages as the motor gains rpms. As this clutch goes bad it takes more Motor RPMs to get it to engage. Sometimes it will engage all of a sudden at higher rpms. If you have to give the motor 1/2 throttle or so before the machine moves and once the motor rev's out it wants to go then this one is the problem. It's the easiest clucth to replace but is the most costly one.
    Tha manual Clutch is the clutch used for shifting. It is activated via some internal parts ( connected to the shifter shaft ) when the shifter is moved ( up or down ). When this goes bad the the machine will move in lower gears and you will notice a slippage ( most all the time ) in higher gears. You should notice when you shift it into a higher gear the motor will want to rev but the trike don't want to go like it should.
    Now you stated:
    This leads me to believe that the centrifical clutch is bad. The centrifical clutch is engaging during higher rpms.
    If it was the Manual clutch the machine would want to slip in higher gears. ( It wouldn't want to wheelie very well ).
    that is my input. I hope it helps!
    Thanks
    Howdy
    Nov 2002
    1,189
    so its prolly the centrifugal. also, if im in 3rd, i get a lot of rpms, and skip 4th gear and go straight into 5th, i can floor it, then the engine will rev down to almost an idling point, and shake alot, like it is jerking, then it is fine.
    My Rides
    Yamaha 200E
