Results 1 to 8 of 8
Thread: How should i fix stripped exhaust studs/bolts in a head?
    Opelousas, Louisiana
    1,337
    Im resealing my 110 topend and i need to fix the exhaust bolts. I believe they have studs from the factory but mine came with bolts. Should i just JB Weld in some studs or put some thread inserts in and put studs or use bolts?
    1986 350X K&N filter, DG Krome Power exhaust
    1982 110 UNI filter, Cobra megaphone exhaust
    1982 honda 110 exhaust for sale, PM me.
    Nov 2004
    Waterloo IL
    2,701
    I have never seen JB weld work on anything and it definitely won't hold exhaust on. Best thing would probably be to heli-coil the head and then screw a stud into it.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Nov 2001
    B.C.
    933
    JB will just burn off. It's just epoxy! Do the Heli-Coil thing, or drill out and retap to the next size.
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Jul 2004
    minnesota
    689
    do what mobular said, just drill and retap new threads., thats probly the most safest and secure way there is.
    my trikes:
    1983 honda atc 200x-k&n filter
    2002 yamaha raptor 660r, yoshimura slip on, prm grab bars
    1978 chevy nova, 454 v8, bds blower, 150hp shot of nitrous, full roll cage, a real power house.
    1991 chevy s10 4x4 350v8.
    1986 250sx
    YES its fast NO you cant ride it.
    staceyl200's Avatar
    staceyl200 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2005
    South Wales UK
    253
    As above but dont tap all the way through because when you drive the helicoil in it will stop > Use the first tap then maybe the second tap then loctite helicoil in . I use these every day in moldtools just dont go right the way thru with the tap as the helicoil or solid insert ( which are alot better) will only screw out when you put the bolt/stud in.
    Jun 2003
    South of Rochester, NY
    3,471
    Ummmm.... put a different head on it? That's how I fix crap like that! Even saved me some big repairs in the future! When we changed the head, found a toasted cam and non-existant lifter arms!
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    1,337
    Quote Originally Posted by 350x'inNY
    Bruce
    i do have 2 spare engines.......
    TRIZTUNES is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2004
    PA.
    150
    how should i fix stripped exhaust studs
    HI!!!
    you can buy a recoil(like) helio coil.
    sold by fastenal.
    it is a kit made for stripped bolts.
    it has a coil insert.so you stay stock size.
    WWWfastenal.com or your local automotive parts supple .
    they range from $8.00-$80.00 depending on size.
    TRIZTUNES
